Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Going over 80% injector D.C.
Old May 6, 2008 | 08:30 PM
Max Lewis's Avatar
I have a 94 camaro z28 6 speed, ported heads stock valves, port matched intake, C.C 1.6 R.R, pacesetter longtubes, flowmaster exhaust, SLP cold air kit, pcmforless tune, pulleys. It has the stock injectors and fuel pump and I notice when I log it with datamaster when it's cutting out the injector duty cycle goes over 80% and flashes red. Does this mean my fuel pump or injectors need upgraded?
Old May 6, 2008 | 09:15 PM
z28_theantirice's Avatar
Time for some new injectors....
Old May 6, 2008 | 11:57 PM
Datamaster seems to produce slightly higher duty cycle numbers than seem logical. They do their calculation right, using the "base pulse width".... but it seems like its not unusual for a mildly modified engine to produce DC's approaching 100%, when there is no evidence of a fuel shortage in the way the engine is running.
Do you have any idea what kind of flywheel HP the engine is making? You mention heads, but not a cam.... still using the stock cam?
You mention only at the end that it is 'cutting out'.... under what conditions - engine RPM, throttle position - is it cutting out?
Old May 7, 2008 | 06:35 AM
Max Lewis's Avatar
I am not sure what the horsepower is, and yes I am still using the stock cam.
The car starts to cut out at 4600rpm and above at 100% throttle. The injector DC is peaking out at around 90%. I don't think its ignition related the plugs, and wires are new and the distributor has only about 2-3 thousand miles on it. The car runs great until 100% throttle at 4600rpm and above.
Old May 8, 2008 | 08:58 AM
slomarao's Avatar
I dont think you ve reached the limits of the stock pump. Probably the injectors. I have a very similar setup to yours (bolt ons+ headwork and stock cam) and im putting 30lbs or 37lbs in mine. But I am also going to run a dry kit so im really going to need the extra fuel. good luck
Old May 11, 2008 | 08:16 AM
PoorMan's Avatar
Just for another comparision, with my mods in sig minus the TB, mine was at 100% DC at WOT running the stock injectors. After the 30lb SVO injectors it drop down to 85% DC.
Old May 11, 2008 | 09:01 AM
Max Lewis's Avatar
Was your car cutting out at 100% throttle with the stock injectors.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
