need to double check stuff, injectors/tb
Old Apr 25, 2008 | 12:13 AM
limige's Avatar
need to make sure i've done things right, it's been awhile since i've done much with the car.
i've added syty injectors, 30-32#'s depending who you ask, my fuel pressure is a solid 60#. cam is 230/236XE and i just added a homemade 52 mm monoblade.
so what's my effective injector size?
for the monoblade i came up with a scaling factor of 1.492 for current displacement from stock. just use that on all the maf tables right (scaling)
and for the injectors you set the constant and scale the injector vs voltage table right?
just want to be sure.
thanks
mike
grgguy
17
Feb 23, 2015 07:57 PM
ModdedNerd
Jan 29, 2015 07:23 PM
squarehead
Jan 15, 2015 07:02 PM
teal98
15
Sep 16, 2002 01:23 PM
Rich_z28
Aug 29, 2002 10:44 PM
