Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Summit Racing Street & Strip Multi-Spark Digital CD Ignitions
Old Apr 21, 2008 | 02:08 PM
kjking89's Avatar
the reason im writing this post is to potentially save someone the headache i just had installing the ignition kit from summit i just bought (part # SUM-CSUM2752). It comes with a HEI distributor, the ignition box and wiring harness.
The main problem was that in the instructions it didnt say you need to remove the 4 pin module and use the magnetic pickup wires. it even has a diagram (fig 15) showing you can use the white trigger wire with the 4 pin module in place, however you can not, in my case the engine ran but would not idle. So, if any of you are looking at this kit and plan to buy the hei version - be sure you remove the module inside the distributor and use the purple and green magnetic pickup wires.
in my opinion summit needs to fix their instructions to be more specific for the HEI dist shipped with the kit, on the other hand it was a good price and works well.
Old Apr 22, 2008 | 03:43 AM
toomchz4u's Avatar
I too have one of these on my 88 GMC pickup and I found the instructions to be confusing compared to the MSD ignitions I've used in the past.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
jasonduaine
Apr 1, 2015 08:09 PM
Collector Car
Dec 17, 2014 01:12 PM
Elcojoe
Nov 17, 2014 10:27 PM
