LS1 Driveshaft for LT1??
Old Apr 11, 2008 | 08:19 AM
LJM97Z's Avatar
Are these a better driveshaft? I hear some talk about them, will they fit in my 97 6sp., if so, what ones can i use, what yrs.? My driveshaft is pretty rusty.
Old Apr 11, 2008 | 09:20 AM
2000GTP's Avatar
They are aluminum so they weight a little less. Just because your steel driveshaft is rusty doesn't mean it will impact your performance though. Otherwise, they won't provide any real power gains. The 98-02 driveshafts will work on your car.
Old Apr 11, 2008 | 09:26 AM
OutKast's Avatar
agreed, if your isn't suffering the vibration problem then I would suggest leaving it as is. I had an LS1 drive shaft for a little while. It now rests in 3 pieces. If you want to go aluminum get the 1LE shaft. The wall thickness of the LS1 shaft is unbelieveable thin while the 1LE has a little more meat to it.
Old Apr 11, 2008 | 10:50 AM
"small" rear wheel power gain, at least LT1 steel vs aluminum 1LE.....
http://www.ws6.com/mod-1.htm
Old Apr 11, 2008 | 12:53 PM
LJM97Z's Avatar
Thanks, my main concern was the rust (not so much a power gain), its well past surface rust, its pitting throughout the shaft, it does look like a sturdy piece though, so if its still ok, i'll let it go for now, there is no vibration that i can feel.
Funny you should talk about the LS1 shafts, just last week, a guy twisted his aluminum shaft in half in the burnout box, this was on a stock TA with street tires (6sp. car), sooooo, i'll stay away from them, thanks for the heads up.
ddr698
Jan 31, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Jazsun
Dec 29, 2014 12:14 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
