Engine whines like it has a blower
Old Apr 10, 2008 | 03:23 PM
1of50's Avatar
My lt1 has developed a whining sound that goes up & down with RPM, sounds like I'm running a blower or maybe a gear drive which I'm not. Any ideas??
Old Apr 10, 2008 | 03:44 PM
cause4panic's Avatar
power steering pump
Old Apr 10, 2008 | 03:52 PM
JakeRobb's Avatar
Super Moderator
Originally Posted by cause4panic
power steering pump
Old Apr 10, 2008 | 08:17 PM
TeamingTealZ28's Avatar
mine does the same somtimes...but not loud..
but do you know HOW MANY PPL think my Z28 is supercharged, i can fool anyone haha
Old Apr 11, 2008 | 03:13 AM
95camaroinok's Avatar
Or possibly transmission if you have an automatic..... Mine did that for a year and a half before it exploded Hopefully its just your p/s pump unless your looking for an excuse to build a better trans.
Old Apr 11, 2008 | 07:06 AM
1of50's Avatar
Thanks Guys, but why do you think it's the PS pump and not one of the other belt driven accessories: alternator, AC compressor? I've heard that bearings in these items also whine. Not the tranny, it's a 6 speed.
Old Apr 11, 2008 | 07:10 AM
6 speeds can still whine but they dont sound like a supercharger. when an ac compressor bearing goes it sounds like a tin can of marbles being swirled around. when an alternator bearing goes it either locks up or has a reaaaally high pitch squeal.
hydraulic pumps( power steering, or auto transmission) often make noise. Mine makes noise too, if its not leaking or pissing you off that much just leave it.
listen to any older ford car(taurus, grand marquis, mustang) all have horrible issues with power steering pump noise.
Old Apr 11, 2008 | 07:29 AM
1of50's Avatar
Sounds good to me, Thanks again.
Old Apr 11, 2008 | 12:31 PM
sn8ke eatr's Avatar
probably p.s pump but it could also be the alternator, it happened to me and everyone thought the car was supercharged haha.
does the whining increase/decrease depending on if the wheels are turned or not? if it whines more at full lock its almost definitly the power steering.
Old Apr 15, 2008 | 08:19 PM
396LT1Z28's Avatar
Did you put a spray-on belt dressing on your serpentine belt?
If you did, it could be that.
Old Apr 15, 2008 | 09:42 PM
shock6906's Avatar
Just see if it gets louder when you go around a corner. If it does, it's gotta be the power steering pump. I know mine makes noise in my Z and sounds like a supercharger. Goes up and down with RPM just like you say yours does.
Old Apr 16, 2008 | 11:21 AM
1of50's Avatar
Just wondering, I had the water pump replaced last summer and as you know it's gear driven, could these gears be making this sound like a timing gear drive set does
P.S. No belt dressing ever, sound seems to be unconnected to steering movement.
Old Apr 16, 2008 | 07:05 PM
wildweasel's Avatar
I had that in one of my old cars. Twas the alternator.
Old Apr 27, 2008 | 10:44 AM
postalbunny's Avatar
my new alternator whines... you can remove the small plug on the alternator and start it up on just battery... if it stops whining that's it.
not sure if this is normal... never noticed it before, got new exhaust etc and put new alt on car and now it whines a little.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
CPFarhood
Jul 25, 2002 02:17 PM
