Evacuation Hooked up Wrong?
Old Apr 10, 2008 | 12:43 PM
600hplt1sm's Avatar
Hello, i just got off the phone with procharger asking a question about evacuating the crankcase. I have the manuel and i have the pcv hose off the drivers side intake hooked up to the tube after the maf sensor and before the tb, and the hose coming out of the passenger side valvecover is basically hooked up the same way. That is the way the manuel says, but the guy from procharger told me those two need to be t'd and routed to the plastic inlet tube on the back of the blower. Does this sound right to anybody
Old Apr 10, 2008 | 02:16 PM
Sparkz28ss's Avatar
yes...
you want the crankcase vent hooked up the the intake side of the blower.. not the pressure side.. or you will be blowing boost into the crankcase..
Old Apr 10, 2008 | 02:20 PM
RealQuick's Avatar
Originally Posted by Sparkz28ss
yes...
Exactly.
Old Apr 10, 2008 | 08:14 PM
600hplt1sm's Avatar
ok ill fix it tomorrow, should i run an air / oil seperator on that line, and what would be the best way to tap into the inlet tube
Old Apr 10, 2008 | 08:20 PM
Blownbird355's Avatar
If you are driving it that way either don't drive it or fix it unless you like oil leaks.
Old Apr 11, 2008 | 09:06 AM
600hplt1sm's Avatar
im assuming anywhere on the inlet tube between the air filter and the blower will be sufficiant to tap into
Old Apr 11, 2008 | 11:26 AM
Fire67's Avatar
Correct, as long as thats AFTER the MAF... You dont want oil vapor going through the MAF.
Old Apr 11, 2008 | 11:52 AM
600hplt1sm's Avatar
ok now im confused, if i tap into it after the maf, isnt that considered the pressure side of the blower, i thought i want to tap in the suck side
Old Apr 11, 2008 | 03:29 PM
Sparkz28ss's Avatar
well...the stock ATI setup has the maf on the inlet side..
like this...
Air Filter--Maf---crankcase vent -----blower-----IC-----TB
most of us move the MAF to the pressure side
air Filter-----crankcase vent ---blower---ic---MAF--TB
I think what Fire67 was saying is if you have the maf behind the filter like the stock ATI setup then dont put the hose infront of the MAf..
Old Apr 11, 2008 | 03:49 PM
600hplt1sm's Avatar
i think i should be good then, I have mine
air filter --- Crankcase vent --- blower --- IC --- MAF--- TB. I also put a Air / oil seperator inline with my crankcase vent lines. I think i have it now, If something doesnt look right with the way i have it now please let me know.
Old Apr 15, 2008 | 08:32 AM
Fire67's Avatar
Looks good to me. It was a good idea to use an air/oil seperator as well. Oil film gets nasty inside intercoolers and MAF sensors.
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
jackpawt883
Sep 10, 2015 08:53 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
