Need answer to running a big shot
Old Dec 17, 2002 | 11:05 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
check sig for mods. Strong bottom end. The pistons are custom Ross with the top ring moved down(less heat with the spray).
Here's the question?
Why couldn't I run a big shot on a high compression motor(12.5.1). I've all ways ran a 175 shot, but with the new combo was going to up it to a 250(will not stay there) for the track visits. I always thought, when running the spray, even with high compression, your ok. Was I miss informed.
Old Dec 17, 2002 | 11:52 PM
CustomN2O's Avatar
There is absolutely nothing wrong with running lots of spray with high compression. Just make sure your timing is cool, and you are running good gas. I have a 14.1 motor, and run a 300 shot. It will run good. Just make sure your total timing is inline, and you dont detonate. I dont want to give a specific timing retard, cause it really depends on a lot of different things, but if you give me some more info on your motor, liking total timing, kind of heads, brand of N2O kit, etc, I could give you some recomendations.
Old Dec 18, 2002 | 10:04 AM
PNYKILR's Avatar
Every thing is in the sig. on my setup
DirtyDaveW
Dec 1, 2016 05:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Louey
Pacific
Nov 28, 2014 03:46 AM
Johnny Hunkins
61
Nov 9, 2002 08:18 AM
Brent94Z
Mar 21, 2002 04:44 PM
