3.73 in a 2 series carrier?
Old Mar 31, 2008 | 11:57 AM
Future_Z_Owner's Avatar
I can purchase aftermarket 3.73s made to go into a 2 series carrier correct?
Old Mar 31, 2008 | 12:48 PM
onebadponcho's Avatar
Yes, the ring gear is thicker than the 3 series, and they're also normally more expensive.
Old Apr 1, 2008 | 06:13 AM
Car Enthusiast's Avatar
i know the difference between a 3 and 4 channel
whats the difference between a 2 series and whatever else
Old Apr 1, 2008 | 07:06 AM
Capn Pete's Avatar
2-series carriers are for low numerical (high ratio) gear sets, ie: 2.56's --> 3.08's.
3-series carriers are for high numerical (low ratio) gear sets, ie: 3.23's --> 4.56's.
Due to the larger pinion gears of high ratios, the carrier is offset approx. ~1/4" to compensate. 3-series carriers allow the ring gear to be positioned ~1/4" closer to the pinion.
That's the only physical difference .
Old Apr 1, 2008 | 06:39 PM
when looking to swap gear sets does it matter as I have 2.73's with a six speed after a swap and need the lower gears
Old Apr 1, 2008 | 11:48 PM
bombebomb's Avatar
If the car orginally had 2.73's, then you have a 2 series and need to get a 2 series gear set, I have the link to my richmond set if you want to take a look pm me. mine are 3.73's
Old Apr 2, 2008 | 07:24 AM
95mysticta's Avatar
yeah you will definetly need to swap out gears as you wont be able to use 6th gear unless your going like 110mph. stock 6 spd cars came with 3.42s i suggest atleast a set of 3.73s while swapping out for a new gear set.
im converting my formula over from a4-m6 and going from 2.73s to 4.10s which will make a world of difference on the street. should be a blast next week when shes all buttoned up!
Old Apr 2, 2008 | 08:09 AM
Originally Posted by 95mysticta
......... stock 6 spd cars came with 3.42s i suggest atleast a set of 3.73s while swapping out for a new gear set.
Depends on the year of his T56.... If he installed a T56 from a 93, it might be the M28, that was coupled with a 2.73, or an M29 that was installed with 3.23's at the factory.
Old Apr 2, 2008 | 01:51 PM
Capn Pete's Avatar
Yeah, good 'ol odd-ball 93's!!
Old Apr 3, 2008 | 01:47 AM
Hey can i get the link to the Richmond 3.73 gears for a 2 series carrier? Thank you.
Old Apr 3, 2008 | 02:02 AM
Crows89RS's Avatar
I got mine from a member on here for like $125 or something...
They're made by Strange, which is a reputable company. Check them out if you wanna.
Old Apr 3, 2008 | 09:03 AM
95mysticta's Avatar
i know richmond makes them and there on summit for like 189 bucks i believe. motive just stepped on board as of late and has a set of 373s for the 2 series and i believe there in the same price range. dont have the link handy but i believe the site i got the info off of was called speed inc. and they have a wide selection.
gl
Old Apr 3, 2008 | 10:20 AM
19z28camaro02's Avatar
Wait wait wait. I thought the 3.23 was a series 2 carrier? Is it a series 3?
Old Apr 3, 2008 | 02:54 PM
Capn Pete's Avatar
Nope. Factory 3.23's ride on the 3-series carrier, NOT the 2-series. That's for sure, not a guess .
Old Apr 3, 2008 | 03:04 PM
bombebomb's Avatar
This thread is beginning to confuse me
Pm's sent to those who asked.
