slipping on overdrive only
Old Mar 30, 2008 | 05:01 PM
antoine's Avatar
slipping in overdrive only
hi,i have 1997 camaro z28 and the problem i'm having is slipping in overdrive but no other gears.first to second ok,second to third ok,third to
fourth ok til you give it some throttle then it starts to slip then it will catch.
Old Mar 30, 2008 | 10:33 PM
Performabuilt's Avatar
Supporting Vendor
Are you sure it isnt just jumping out of lockup and then back in?
Old Mar 30, 2008 | 10:58 PM
antoine's Avatar
i'm sure,when it goes into fourth gear and you apply some throttle it will slip then grab
Old Mar 30, 2008 | 11:46 PM
Supporting Vendor
Hmm odd the band that holds in 2nd is the same as 4th I would guess if it is indeed doing that its actually the 3-4 clutch failing slippng under load
Old Mar 31, 2008 | 01:01 AM
2001SS4Doc's Avatar
identical thing started to happen to my 4L60 back in November, rebuild. end of story
Old Mar 31, 2008 | 05:44 PM
antoine's Avatar
so the 3-4 clutch pack is gone? or this trans guy was saying maybe the
forword sprag.
IndyZman
Oct 22, 2015 02:17 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
ZXXVIII
Sep 1, 2015 10:13 PM
Jul 17, 2015 02:47 PM
