Power Steering
Old Mar 25, 2008 | 08:38 PM
lt1loudmouth07
Guest
Posts: n/a
Power Steering
I am leaking power steering fluid really bad and i took my ps pump off and its all over the bottom but where at on the pump does the fluid leak out when its bad is it under the pulley. I checked all my hoses and they are not leaking hopefully lol we will find out when i get a new pump
Old Mar 25, 2008 | 11:56 PM
Fatdog2's Avatar
Could be from previous overfill at the pump,does the rack have fluid all over it and dripping,?When my rack went,it was a lot,and that is where the leak really was.Hope this helps.my02
Old Mar 26, 2008 | 10:19 AM
ss.slp.ls1's Avatar
Let us know how it goes.
Old Mar 26, 2008 | 10:30 AM
lt1loudmouth07
Guest
Posts: n/a
pump
Yea on my power steering pump its really weird i could not find where it leaks i am really hoping its the pump and not a hose leaking but i i will say my ac compressor was covered in power steering fluid and also when i turned any direction u could here that pump wine like crazy like i had a procharger on there or something lol but we will find out when i get the new pump on there today
Old Mar 26, 2008 | 10:44 AM
heavyc's Avatar
Sounds like the ame thing i have on mine tell us how it works (im too lazy to find out whats wrong)
Old Mar 26, 2008 | 10:51 AM
ss.slp.ls1's Avatar
From what you are describing, sounds like it is the pump. I had to change my ps pump because it was making awful noise, and my pressure line was leaking. You'll probably be surprised at how quite and smooth your steering will be after the install, I was.
Old Mar 26, 2008 | 11:14 AM
lt1loudmouth07
Guest
Posts: n/a
Ps
Yea i will let you guys know how it goes when i get off work at 7 i am going to install the new pump i will probley have the most trouble getting the damn pulley off lol
Old Mar 26, 2008 | 11:58 AM
ss.slp.ls1's Avatar
Its pretty straight forward:
Remove the two mounting bolts, you have to fish a the extension and wrench through the holes in the pulley. Unclasp the reservoir hose, unscrew the pressure line. Its helpful to unscrew the pressure line at the rack, to free up some wiggle room to unscrew it at the pump, careful not to round it off. Once its off, you just use a ps pump gear puller, you can borrow one from AZ. Pull off the pulley and seat it on the new pump using the installation tool that comes in the same kit as the puller. Mount the new pump, hook back up the pressure line and the reservoir hose, top it off and you are good to go.
Good luck.
Old Mar 26, 2008 | 12:10 PM
lt1loudmouth07
Guest
Posts: n/a
ps
Do i have to prime the pump or anything like that when i get it on. And they say not to push the pulley all the way back but on mine now it looks like its all the way back lol. And i tried to aim you ss u did not respond
Old Mar 26, 2008 | 07:43 PM
lt1loudmouth07
Guest
Posts: n/a
ps
Just to let everyone know. That i replaced the pump and the car could not steer any better the new pump fixed all my problems. thanks for all the help.
Old Mar 27, 2008 | 01:37 AM
ss.slp.ls1's Avatar
Exactly what I thougth would happen. Check the resevoir a couple of times after running it, to make sure the level didn't go down due to air escaping, or a leak of course.
EDIT: Sorry about not responding, I've been getting alot of spam im's. I'll open up im's from now on to verify that they are indeed spam. I'm happy to help.
mspennyhughes
Mar 1, 2015 03:50 PM
