Where/what is a good 383 kit?
Old Mar 19, 2008 | 10:15 AM
GhostZ28's Avatar
My motor crapped out on me with a connecting rod knocking. Since its almost cheaper to buy a new engine than to rebuild to original, I want to cough up the extra money and go bigger. Can anyone give me advice on the best bang for the buck and good, proven brands/parts? I'm looking to spend around $2500 on parts.
Old Mar 19, 2008 | 10:57 AM
Kraest's Avatar
Retired
If I were you, I wouldn't go the 383 LS1 route because it makes the motor undersquared.
When you look at blockwork and everything else, it's basically the same price to put together a 402 LS2 or 408 LQ9 motor. You'll need new pistons (.005" over), rods, and crank for the 383....a full bottom end...just like the 402 or 408.
The only real difference is buying an LQ9 or LS2 block, but if you sell your stock LS1 stuff, you can make up the difference easily enough. Also, you don't need a bore or hone with the 4.00" bore stuff like you do with the .005" over LS1 block, so you save money on machine work there as well if you want to cut costs.
Anyway, you aren't going to find an LS1 forged reciprocating assembly for that price. Maybe an LT1, but the LS1 stuff starts at around $3000 for forged internals.
The Eagle bottom-end costs around $2900 for everything balanced. Then you add another $800 or so for the block work, then another $800 to build the motor, plus whatever it costs to R&R it ($700+), etc unless you're doing the work yourself (please don't do it again. )
Mike
Old Mar 19, 2008 | 03:14 PM
GhostZ28's Avatar
No I'm NOT doing this myself, at least not the rebuild, I am currently pulling the engine myself, they wanted around 1800 in labor alone for that. The machine shop wants 1100 for the rebuild (estimated with machine work) and it'll cost me 2900 for a bottom end so I'm thinking when its all done around $5000?
So an Eagle rotating assembly is probably the way to go?
Old Mar 19, 2008 | 05:42 PM
Greed4Speed's Avatar
For the cost you just quoted on the rebuild and bottom end you could buy a 408 short block from TSP and have $500 left over to cover shipping.
http://www.texas-speed.com/shop/item...id=46&catid=28
Old Mar 19, 2008 | 08:20 PM
Kraest's Avatar
Retired
The Eagle is the way I'd go. I had it in my 408 and it ran flawlessly. Supposedly if you go with the upgraded bolts, it can handle 1000 horsepower.
$1800 for an R&R is absolutely ridiculous. You're looking at $1000 max from an LS1-oriented shop.
Mike
Old Mar 19, 2008 | 08:22 PM
Kraest's Avatar
Retired
Wow. That's a very nice deal.
Old Mar 20, 2008 | 10:11 AM
GhostZ28's Avatar
The texas speed 408 sounds like the best deal considering thats not much more than a stock LS1. Do you think I can get a discount for ordering extras and being a CZ28 member?
And what else will I have to buy with this, new head bolts/studs and head gaskets? I'd saearch more but I dont have a computer at home anymore, and up at work they trip the **** out when they catch someone browsing..
Old Mar 20, 2008 | 10:20 AM
Marc 85Z28's Avatar
You won't get anything for being a CZ28 member But if you buy multiple items, and expensive ones at that, they may work with you on the pricing - they did for me
Old Mar 20, 2008 | 01:41 PM
Kraest's Avatar
Retired
I'd get the ARP studs ($250) and new GM gaskets. You might want to figure out what your compression will end up being with -2cc pistons. It's going to be much higher using the same heads on the 408 than on the 346. As long as you don't go much over 12:1, you should be ok on 93 octane. My 408 was nearly 13:1 and it ran on 93 octane flawlessly. Needed a splash of race gas at the track, though...just for safety
Mike
Old Mar 20, 2008 | 09:52 PM
Me>you's Avatar
TSP 408 is the best way to go...Don't have to wait for a machine shop or anything like that, plus it'll probably end up being cheaper...Of course, you won't want to just bolt back on your LS1 heads to that, so might as well get yourself some good ported heads, and a Fast intake...I see you have some heads, but not quite sure which ones...
Also, i've seen many dealings in the past with TSP taking forever to get a shortblock to you, so make sure they have it in stock ready to go
Old Mar 21, 2008 | 08:16 AM
Kraest's Avatar
Retired
I agree. The 408 (or any stroker motor for that matter) will make decent power with the heads + F13, but nothing too crazy. Probably around 460-470rwhp/rwtq.
Mike
D1SC383LT4
Jan 1, 2016 01:56 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
