My fans turn on when i start the car..turn off after 1 minute ??
Old Mar 18, 2008 | 06:41 PM
TeamingTealZ28's Avatar
I was told my shoebox that the fans are NOT supposed to go on when the car starts.
I did an oil change today so I had the car up on ramps.
So i started the car and crawled under and they would stay on for about 1 minute, then turn off.
Also they would make this high pitched whiining noise.
any suggestions??
Old Mar 18, 2008 | 07:13 PM
Scan it for trouble codes.
Old Mar 18, 2008 | 08:49 PM
The SES light is not on. and I just got it inspected in NY and he hooked it up and it passed..so??
Old Mar 18, 2008 | 11:05 PM
The light does not have to be on for codes to be stored, but if none are coming up, I don't know what could be causing it besides a wiring issue.
Old Mar 18, 2008 | 11:26 PM
It has a SLP Fan Switch installed. but with it OFF it still turns on when i start it
wud that effect it?
Old Mar 18, 2008 | 11:43 PM
Lt1t56's Avatar
The high pitch whine noise you hear when starting the car could be the smog pump running.
I could be mistaken but every time you start the car the electric smog pump will run for 2 minutes after the car is started.
Old Mar 19, 2008 | 12:01 AM
I turned the car on and crawled under
when the high pitched noise went off, so did the fans...so i think its the fans, i gotta double check tomorrow
Old Mar 19, 2008 | 07:23 AM
wud that effect it?
Since the SLP switch is plug and play, disconnect it and see if the same thing happens.
Old Mar 19, 2008 | 10:33 AM
Alright. I will try that. Thank you
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
formula79
26
Aug 5, 2002 12:21 PM
