V-body rear end fit in my F-body?
Old Mar 14, 2008 | 10:31 AM
tmartellc's Avatar
I want to change my rear end out my 1995 Z28 6 speed with the rear end out a 2006 GTO 6 speed. Will it bolt right up or will I need to make special mods. Is the GTO rear end better than my stock rear end?
Old Mar 14, 2008 | 11:00 AM
The GTO has an independent semi-trailing control-link rear suspension. Your Z28 has a solid rear axle with a torque arm. It's not likely any parts would be interchangeable.
Old Mar 14, 2008 | 11:07 AM
tmartellc's Avatar
Old Mar 17, 2008 | 12:17 AM
NovaTodd's Avatar
One more thing about the GTO rear - it has SERIOUS wheel hop issues with stock (for a GTO anyway) power levels.
Old Mar 17, 2008 | 06:29 AM
BigBadBlack93Z's Avatar
if you're set on going IRS try looking into the cobra rear. there were several companies a few years back that made a kit to bolt it right into a fox body no reason you couldn't adapt one to the f-body.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
