Looking for pics of p600b/Install??
Old Mar 14, 2008 | 08:00 AM
bski224's Avatar
Hey just picked up a Twin intercooled p600b. Anyone have any pics of install?? Also how was the install???
Old Mar 14, 2008 | 11:26 AM
Greg88's Avatar
I just installed mine about 2 months ago, it is very easy with some mechanical knowledge. It is pretty straight forward.
Old Mar 14, 2008 | 03:55 PM
bski224's Avatar
Thats what Im assuming. They want $1500 w/o tune in NY to install. Thats not going to happen. How did you tap your oil pan. Also how was it once she was installed. Im sure once that foot was buried into= FUN!!!
Old Mar 14, 2008 | 04:00 PM
Greg88's Avatar
I sent u a PM, so check that out, if you have decent mechanical knowledge, a long weekend and it goes in fine, taping the pan was easy, I left the pan on the motor and just put some grease around the hole, i hit it with a punch then drilled a small pilot hole. After that i drilled it out and flushed the heck out of my pan with oil and brake cleaner then some more oil. After that i just taped the pan. Its a totally different car now, i only have the 8lb pulley on it, but its only reading around 5-6 pounds at the motor. But it's a rocket now compared to stock.
Old Mar 14, 2008 | 05:15 PM
bski224's Avatar
Awesome!!! any ideas where I can find an 8lb pully??
Old Mar 15, 2008 | 04:51 PM
flusz28's Avatar
where did you guys get your P600B's from? buy them used? i have been looking and have not been able to find anyone selling one.
Old Mar 16, 2008 | 12:09 AM
Boosted_Z28's Avatar
Keep looking in the "for sale" section here, they pop up all the time. Also check e-Bay. Geez, I could barely "give" mine away when I was upgrading to a larger unit a while back.
Old Mar 16, 2008 | 12:13 AM
Did you get the install manual with the kit? If, not, call Procharger, update them by giving them the serial number of the unit you purchased and they will usually send you the manual.
If you are looking for parts, call Bob at: http://www.exoticperformanceplus.com/ He will take good care of you.
Old Mar 16, 2008 | 12:21 AM
bski224's Avatar
Yup, called and they have manual on the way. Hope its detailed for application. You can find the p6oob for a good deal. Great procharger for a great deal.
Old Mar 16, 2008 | 07:24 AM
flusz28's Avatar
okay i will keep looking!
Henson071
Dec 30, 2015 09:55 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
meissen
Aug 11, 2015 06:05 AM
cjamen
Jul 27, 2015 12:48 PM
cmsmith
Jul 10, 2015 07:19 PM
