ticking noise...
Old Mar 13, 2008 | 04:52 PM
hughett17's Avatar
Question ticking noise...
in the mornings and after the car sets for a while i go to start it and it ticks until it gets warmed up i know a few things it could be but...the question is ...im puting a cam in the car along with springs and hardened pushrods should i maybe but a set of lifters and or sone rocker arms or see if it quits after the springs are in im hoping the rockers just need adjusting . the car has 100k + miles on it but i was just wanting some input on what my options are and how to handel it because now im broke and i want it to be fixed before it messwes something else up....thanks
Old Mar 14, 2008 | 10:33 PM
Zitty'sZ's Avatar
The ticking you are hearing is more than likely piston slap which is common in the LS based engines. The rockers are non- adjustable and are torqued to 22 ft lbs period . If I were you and you are thinking of changing the heads and cam, I would buy new lifters and a new oil pump. It wouldn't make any sense not to change them out while you have it apart seeing that they have 100,000 miles on them .
1slow93z28
Sep 1, 2015 06:22 PM
MyfateZ28
Parts Wanted
Jun 20, 2015 11:02 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
importkiller94
Jan 17, 2015 09:03 PM
Punisha69
Feb 1, 2003 10:36 PM
