How much oil and what weight for my 98 LS1?
Old Mar 13, 2008 | 11:14 AM
CALL911's Avatar
I know its probably been discussed before, and its a very basic question, but was not able to come up with good search results.
How much oil will I need for an oil change in my 98 LS1. I plan on going with the standard AC Delco filter, not one of the larger than factory sized ones.
I think its like 4.7 quarts or something like that, but I don't remember, and I can't remember what weight of oil I should be using.
Old Mar 13, 2008 | 11:25 AM
2001NBMZ28's Avatar
5.5 quarts of either 5 or 10W30.
Old Mar 13, 2008 | 11:32 AM
98mustang_vert's Avatar
This man speaks the truth.
Old Mar 13, 2008 | 11:45 AM
CALL911's Avatar
Is that what the manual says? I'm just wondering what it is supposed to be from the factory.
You guys might be right, but I thought it was an oddball amount like 5.7 or something quarts.
Old Mar 13, 2008 | 01:16 PM
Matt 823's Avatar
yea its just about 5.5 quarts everytime I change my oil
Old Mar 13, 2008 | 01:29 PM
Marc 85Z28's Avatar
Most go with 5.5 quarts. After doing a little research when I had my engine out, you can run almost 6.5 quarts without the oil level coming into contact with the rotating assembly even with the engine off. I run 6 quarts with a stock sized filter. The more oil the better.
Old Mar 15, 2008 | 08:55 PM
midnightnavyz28's Avatar
...put in 5 quarts then check the level...prolly have 2 add another 1/2 quart..more oil the better?...too much oil is worse than not having enough....let me know when ur oil starts forcing itself out of the block
Old Mar 15, 2008 | 08:59 PM
Marc 85Z28's Avatar
Originally Posted by midnightnavyz28
marc u r an idiot....more oil the better?...too much oil is worse than not having enough....let me know when ur oil starts forcing itself out of the block
Did you not read my post? Anyway thanks for the advice I keep you up to date on the oil "forcing itself out of the block". And yes, the more oil the better - as long as it doesn't create windage problems.
Old Mar 17, 2008 | 06:45 PM
Syn's Avatar
Syn
i've ran the thicker 5w40 as some people swear by on ls1tech it made my oil pressure then normal
but 5w30 has been good to me
6qts
Old Mar 22, 2008 | 02:56 AM
2001SS4Doc's Avatar
5.5 qts Mobil 1 Synthetic 5w30 and a AC delco PF46 filter
I heard that Castrol Syntec gives 5 HP and the free sticker gives another 5, but only when you put it in the engine bay
Old Mar 22, 2008 | 03:14 AM
MasterZ28's Avatar
Does it matter how many miles the engine has like mine?
Old Mar 22, 2008 | 07:29 AM
Z28luvr's Avatar
no...my car has 137k and I have no oil pressure issues with M1 5w-30
Old Mar 23, 2008 | 11:50 PM
2001SS4Doc's Avatar
I just turned over 92K and my only complaint is the damn rings on my 2001...burns a scoche of oil (1/2 qt every 1500-ish miles), nuthin compared to a '86 suburban I had for a while.
anyway mileage does not really matter, its debatable to go to the "high milage" M1.
Old Mar 23, 2008 | 11:55 PM
Me>you's Avatar
Mine used to burn everything but 5w-50GC, or 5w-40GC
Old Mar 24, 2008 | 01:29 AM
2001SS4Doc's Avatar
WTF is that stuff normally used for?? and would that be cool to use it in my baby...she only like the slickest lube
