Brand New 383 Problem
Old Mar 12, 2008 | 08:02 PM
99ztwty8's Avatar
We just got my 383 started up for the first time. We let the car run for 20 min's at idle. Car ran rich but good, that was just with the start up tune on the computer. Went to go start it up a week later, for the second time, car only runs on the passenger side cylinders. We have spark and fuel. The car back fires like crazy when started. Checked grounds and everything like that. Does anyone have any idea what could be causing this? I've also heard that the coil pack's are numbered? Is that true? I have never heard of that before. I dont mean to sound like a idiot but, ??? We can' figure it out! The motor was proffesionally built. Once again, the car ran the first time we tried starting it, now it wont idle and it back fires the second you start turning the motor over! We have 58lbs of fuel pressure! Any help at all?
Old Mar 13, 2008 | 10:26 AM
Marc 85Z28's Avatar
The coil packs aren't numbered, but switching the coil pack rails from side to side will cause problems. But if it started and ran OK on the initial startup, that isn't your problem.
You say you have fuel and spark present on all cylinders right? When you say "fuel", are you just checking fuel pressure or did you verify that the injectors are actually working?
ALL grounds are OK? You double and triple checked? Any DTC's? Do you have a scanner that is capable of monitoring both the cam and crank sensor?
Old Mar 13, 2008 | 05:29 PM
99ztwty8's Avatar
I am 100% positive that the injectors are working. I do have a buddy that is a mechanic and has a computer than can monitor the motor. This whole thing is just blowing my mind! I actually called wheel to wheel performance today, they are one of the best LS1 tuners in the nation in Detroit, Michigan, and it boggled their mind? Just really pi$$ing me off!
Old Mar 14, 2008 | 08:36 AM
AL SS590 M6's Avatar
Moderator
The only time that I ever experienced a problem like that was when we missed the 3rd ground on the back of the DS head.
Old Mar 17, 2008 | 05:31 PM
99ztwty8's Avatar
I'll check to make sure that 3rd ground is on the back of the DS Head! Hey any little bit help's! Any one else have any idea at all?
Old Mar 24, 2008 | 04:05 PM
99ztwty8's Avatar
Ground's are all good!? Anyone have anything else.... Anything at all?
Old Mar 24, 2008 | 04:14 PM
Me>you's Avatar
how's the head gasket on that side? Pull all those plugs too...
Maybe the pistons on the passenger side fell out...
Old Mar 24, 2008 | 04:15 PM
dangalla's Avatar
make sure you go over the whole motor and check all your connections really good
and check for loose pistons in the oil pan
Old Mar 24, 2008 | 04:34 PM
99ztwty8's Avatar
Checked... No pistions in the oil pan... Thank GOD! Check all connections!
Old Mar 28, 2008 | 03:42 PM
99ztwty8's Avatar
Does anyone have anything that tells were all of the grounds are and what they are for? I want to check every connection again! Anyone??
Old Mar 31, 2008 | 08:23 PM
99ztwty8's Avatar
Old Apr 6, 2008 | 08:19 PM
99ztwty8's Avatar
Nothing?
chevy95z28
Jun 22, 2015 09:28 PM
alliance12364
Mar 6, 2015 04:39 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
