nitto drag radials
Old Mar 5, 2008 | 10:03 PM
97sscamaross's Avatar
nitto drag radials
ok, i have a question. I have a 97 ss slp with the 3.42 gears and I am thinking about putting some nitto 555's on the rear. I know they're great tires but my only concern is when I run my car I don't want to hurt the rear end. should I have to worry about this? and also what do you suggest me getting, the 275's or the 315's?
Old Mar 6, 2008 | 12:58 PM
Since you have 3.42's, we'll assume you have an M6 tranny. Generally, an M6 with high HP, big RPM clutch dumps and sticky tires is risky with a stock 10-bolt. On the other hand, we have no idea what kind of power you are putting down. "Stockish" power levels shouldn't be a problem.... 500HP and a 5K clutch dump and you will have a problem. Are you planning on running these on the street, or on a well-prepped track? Are you asking about 275 or 315's because you are only interested in using your stock 17" wheels?
Why not add a "signature" with basic info about the car - year/model/engine/trans and any major mods. That will save you having to type the info in every post.
Old Mar 6, 2008 | 01:14 PM
yeah, all I have is bolt on's but in the next couple years i'm looking to make around 450 hp with a good set of heads and a cam, maybe a small shot of spray. I will be using the stock 17 inch wheels also for the tires.
Old Mar 9, 2008 | 09:44 PM
my954mula's Avatar
You ought to get a 12 bolt to keep handy. Believe that.
Old Mar 9, 2008 | 11:23 PM
yeah, I think I'm a hold off on the dr's until I put a 12 bolt on the car, just to be safe and all
Old Mar 16, 2008 | 09:11 PM
Sinister95Z's Avatar
With the power level you are at now, DR's will be no problem. For the stock 17" wheels, go with the 275's. A 315 is too wide for the stocker. By the time you are ready for the heads/cam, you will need a new set of tires and wheels anyways.
RUENUF
Mar 13, 2016 03:37 PM
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
