Support engine while removing transmission?
Old Mar 4, 2008 | 08:46 PM
droptop z's Avatar
I'm gonna be changing my clutch out pretty soon, and just needed to know if i need to support the engine in any way while the transmission is removed.
Old Mar 4, 2008 | 08:50 PM
maverickmk's Avatar
you don't "have" to but it's a good idea - use a 2X4 on a floor jack under the oil pan or a hoist on the engine
Old Mar 4, 2008 | 09:26 PM
ulakovic22's Avatar
Yeah, you don't have to and a little tilt is actually good so you have room to pull the tranny out. It's really a personal preference.
Old Mar 4, 2008 | 10:59 PM
Sleeper_Z's Avatar
I agree. I would support it. If you had long tubes the headers would actually sit on the k-member but sense you have shorties it would be pretty hard on the motor mounts just hanging there. Good luck on the clutch swap. Make sure you grab a buddy to help. That sucker is HEAVY when its sitting on your chest :S
Old Mar 5, 2008 | 04:35 PM
carolinacasper's Avatar
I would support it. I didn't on mine at first, and it bent my motor mount brackets slightly. No serious permanent damage though.
Old Mar 5, 2008 | 07:36 PM
max_ta's Avatar
like someone posted above let it tilt,but watch your oil psi sensor.With the tilt it is easier to get to bell housing bolts
Old Mar 8, 2008 | 12:43 PM
JP95ZM6's Avatar
Just REMOVE THE OIL SENSOR. The clearance helps, since you can tilt the engine further.
I was careful until I couldn't get the top bolts late at night, kinda forgot, and busted it anyway.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jul 4, 2005 05:00 PM
guionM
10
Sep 8, 2002 11:08 PM
centric
Aug 15, 2002 09:04 PM
