how hard should a motor be to turn over by hand
Old Feb 28, 2008 | 06:11 PM
Syn's Avatar
Syn
i just put my new pistons in and its hard to hard to turn if i try to spin a part of the crank, all the pistons were gapped properly just maken sure that its normal, like if i grab part of it and try hard it barley moved
mdacton's Avatar
not good.
Old Feb 28, 2008 | 06:13 PM
mdacton's Avatar
Without the pistins in it can you turn the crank with your bare hand? If not pull it back apart.
Whats the piston to wall clearance? ring gaps? rod and main brg. clearance?
Old Feb 28, 2008 | 06:19 PM
Syn's Avatar
Syn
without the pistons in it spun no prob, top ring is .020 2nd .022 main clearence was .0001-2
i didn't check piston to wall clearence how do i do that
Old Feb 28, 2008 | 06:45 PM
ss.slp.ls1's Avatar
If its in the car, with sparkplugs in place, in neutral, it requires a good amount of force with a wrench to turn it over, but it shouldn't require the force of lets say...jumping on a breaker bar.
Old Feb 28, 2008 | 07:06 PM
mdacton's Avatar
are you sure? We normally go .003" I would look for .0025 at a min.
Ring gaps sound fine. If you don't have a piston mic and dial bore gauge the put the piston in the cyl. and see what feelr gauge you can get down in there beside it. Your pistons should have told you what it should be....it will not be perfect but pretty close. Without a tq plate on it and being kind of a crude way of checking it....if its close I would say your fine.
It has to be something in that bottom end. I also guess this is on a stand? Be sure you get this fixed, if not its going to get tight and blow up real quick
Old Feb 28, 2008 | 07:19 PM
Syn's Avatar
Syn
yeah its on a engine stand, well i figured out what it was, the jackass taylor sims from dallas powerhouse, hes on ls1tech sold me the wrong pistons telling me they were right
the rear driverside piston hits the crankshaft, so am i screwed or can i fix this somehow?
Old Feb 28, 2008 | 07:27 PM
mdacton's Avatar
well need to know where how and why its hitting.......if its not too bad I guess you can do something.
I'm not an lsx guy so I don't know. Kraest probly does.....he can lead you in the right direction, I just have some basic general knowledge
Old Feb 28, 2008 | 08:00 PM
Kraest's Avatar
Retired
Get the correct pistons. That should be a no brainer
Old Feb 29, 2008 | 06:47 AM
AL SS590 M6's Avatar
Moderator
I agree. Pull it back apart and send the pistons back then get the right ones from someone else.
Old Feb 29, 2008 | 02:23 PM
Marc 85Z28's Avatar
Is the piston hitting the crankshaft or the crankshaft position sensor reluctor ring? LS1 strokers need the rear piston clearanced for the reluctor ring - not all aftermarket pistons have this!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
formula79
26
Aug 5, 2002 12:21 PM
