02 sensor?
Old Mar 1, 2008 | 06:05 PM
Sunsetmaro's Avatar
02 sensor?
Well on my way to work, the engine light came on. I have a code reader and it says " Catalytic effic (bank 1) probably meaning one of my 02 sensors went bad... but I can't figure out where "Bank 1" is located....
Old Mar 1, 2008 | 07:12 PM
Z28luvr's Avatar
driver's side...if I'm not mistaken
Old Mar 1, 2008 | 07:40 PM
ss.slp.ls1's Avatar
Post the exact code, bank 1 is drivers side, and catalytic efficiency below threshold might mean you have a bad sensor, burnt wire, or a bad cat.
Old Mar 1, 2008 | 07:56 PM
Marc 85Z28's Avatar
Bank 1 catalyst efficiency below minimum threshold
Basically that means your drivers side catalytic converter is not working properly. Take it to a dealer that is mod friendly and they will replace the converter free of charge and delete the DTC from the PCM.
Old Mar 1, 2008 | 08:12 PM
2001NBMZ28's Avatar
Yep, sounds like P0420 - bad cat most likely. 00-02 F-body cats got an extended warranty by GM for 10yrs/120K in December 06.
Old Mar 2, 2008 | 03:09 PM
Sunsetmaro's Avatar
How would I know if its a bad cat or bad 02 sensor? I had a buddy tell me to take a look and see if its burnt out, which im sure all of them would look sh*ty and burnt because exhaust goes through it... That is the code it reads btw.
Old Mar 2, 2008 | 03:11 PM
2000GTP's Avatar
Try swapping sensors from bank to bank. If the other bank is reading low catalyst efficiency, then that should point to a bad 02 sensor.
Old Mar 2, 2008 | 06:50 PM
Marc 85Z28's Avatar
Faulty O2 sensors don't cause catalyst inefficiency codes. That is a myth, forget you ever heard it. Take it to the dealer already - its FREE!
Old Mar 3, 2008 | 09:58 AM
2001NBMZ28's Avatar
www.gearchatter.com/viewtopic9353.php
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
