Ben, you finally get your car???
Old Dec 14, 2002 | 09:13 PM
slvrbird2000's Avatar
I keep seeing you post that it's a beast and you blew the trans etc. You finally got it? What trans does it have? Don't leave us hangin!!!
Scott
Old Dec 14, 2002 | 09:44 PM
Bloodztone's Avatar
Okay, yes it's official I got the car back and it's in my driveway. There are a couple of issues with it but nothing major. It's a monster! It's got a rebuilt 4L60E and we'll see how long it holds up. This is not a stock 4L60E, it's been upgraded. Let me just say the car has more power than anything I've ever been in, including supercharged cars. I've never had a chance to drive Jims so it's not quite that kind of power, but heads and cam feel like a pinto on it's last leg compared to this. The car hauls butt! We did a few 3/4 throttle runs in Houston and it blew away my expectations. By far this is a high 10 second car easy. I've never felt anything pull so hard at 80mph. I still haven't done a WOT run, and I probably won't until everything is broken in. Doesn't matter, the power is insane anyway.
Old Dec 14, 2002 | 10:13 PM
the right formula's Avatar
Congrats Ben!!!!!!! I'll definately be at the Sonic meet if a 422 will be present!
Old Dec 14, 2002 | 10:20 PM
Cool! So you wanna race?
ROFL
Can't wait to check it out. I'll be back in SA this Wednesday for the break until Jan 12th.
Take care,
Scott
Old Dec 15, 2002 | 12:04 AM
pink68's Avatar
Yeah!!! Finally got it!!! If your interested in going to Alamo with it on Wednesday give me a call at home Ben. I am taking my car and will be tuning a Hemi car that night too. Let me know!
Jim
Old Dec 15, 2002 | 01:15 AM
PG's Avatar
PG
damn now I want one too, hehe
That good that you got it back. How loud is it?
What of your rearend did you get it installed yet? Well let us know what you run in the 1/4 right now is good weather for it.
Old Dec 15, 2002 | 10:01 AM
Bloodztone's Avatar
Rearend won't go in until the 28th. I can't race the car yet because it's already got the 3.42 gearing programmed in it and it will be bouncing off the rev limiter until I get the 3.23s out. Once the rear end is in and I break it in some I'll be ready to race again. Probably early in January. The car is a lot louder than it was before and just by listening you can tell it isn't a 346.
Old Dec 15, 2002 | 05:13 PM
Bloodztone's Avatar
Okay update on the car, it's not turning over now. Dom came over and helped me look at the car. At first I thought it might be electrical but that got ruled out. We were going to change the fuel filter also thinking that might be clogged but it seemed ok. I've come to the conclusion after running a few searches that I probably need a new fuel pump. I still have the stocker in there and that isn't going to handle the flow I need. So I'll be getting a new fuel pump soon and having that put in. I'll keep everyone updated.
Old Dec 15, 2002 | 05:18 PM
Stock fuel pump on a 422?
Walbro 255 lph will suit you just fine. The install is not that bad I do not think, I'll look around for the install guide.
Scott
Old Dec 15, 2002 | 06:10 PM
eddiezlt1's Avatar
Scott
very easy
under an hour
once you do it the first time
you can change it in under 20 min
Old Dec 15, 2002 | 07:35 PM
K!D's Avatar
K!D
Ben, thats bad *** that you got your car back I've got to hear that bad boy!
Old Dec 15, 2002 | 08:08 PM
97 RedSS's Avatar
BWAHAHAHAHAHAHAH...in under 20mins?
Thats just too funny..Your saying you can drop the rear-end,drop the tank,unplug all the fuel fittings,pull the old fuel pump out,replace the pump,put it back in tank,put tank back in car, and put rear-end back in!!!! If you can do all that in under 1.5 Id give ya a million bux...
Dont do it the cheap way either and cut a hole in the back of the car to access the fuel pump..Go with the Racetronix plug and play kit by the way..very good pump and the voltage actually goes up at WOT apposed to the stock fuel pump wiring dropping nearly 1 volt..
Cody
Old Dec 15, 2002 | 08:40 PM
eddiezlt1's Avatar
Cody
i make the hole the only way to do it
only silly people would drop the tank
Old Dec 16, 2002 | 10:56 AM
T-Rod's Avatar
Ben,
You definietly want to go with the racetronix fuel pump. It's plug and play for us '98's. It's going to be the best application for what your looking for and you can always add an inline pump later if you put the super or plan to spray.
liamcg97
Nov 25, 2019 05:55 PM
ANDYZ28
Dec 29, 2014 09:13 PM
ChrisFrez
Dec 7, 2014 06:01 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
