Getting a Solobaric L7... what ohm model?
Old Feb 3, 2008 | 10:12 AM
kick Z tail out's Avatar
Question Getting a Solobaric L7... what ohm model?
I'm going to be running a 600Wx1 bridged, 2 channel amp.
Never dealt with a DVC sub before... Should I be getting a 2ohm, 4ohm, or...?
Old Feb 3, 2008 | 03:09 PM
Eric H's Avatar
What impedance can your amp run at when bridged? 2 ohms? 4 ohms?
Old Feb 3, 2008 | 04:01 PM
Eric H's Avatar
I remembered stumbling across these pictures years ago, so I'll just answer your question either way...
If your amp can handle a 1 Ohm bridged load, get a 2 Ohm DVC sub and wire as follows:
If your amp can handle a 4 Ohm bridged load, get a 2 Ohm DVC and wire as follows:
If your amp can handle a 2 Ohm bridged load, get a 4 ohm DVC and wire as follows:
And finally, there is the option for an 8 Ohm load using a 4 ohm DVC driver:
Old Feb 3, 2008 | 04:29 PM
Smile
I don't know what it's stable to, but I do know that I used to run it at 4 ohms.
Old Feb 4, 2008 | 02:28 AM
94CamaroZ28's Avatar
It'll make more power at a lower ohm load, but may not be stable there. Research, find out what it'll run stable at, and choose accordingly.
Old Feb 4, 2008 | 12:11 PM
Eric H's Avatar
What is the make/model of the amp?
Old Feb 4, 2008 | 12:38 PM
JakeRobb's Avatar
Super Moderator
JL Audio > Kicker.
That's all I have to contribute here. The other guys are right, though -- find out your amp's minimum stable impedance and use that.
If you like sound quality more than SPL, consider using something higher than the minimum.
Old Feb 4, 2008 | 01:14 PM
PentaVolvo's Avatar
most likely its only 4 ohm stable bridged, so get the D2 and wire in series for a 4 ohm load
Old Feb 4, 2008 | 04:36 PM
I'm shooting for just a 4 ohm load again, because I know it was stable and performed well.
It's a USAcoustics 2200F. The amp itself is probably 5 years old actually.
Originally Posted by JakeRobb
JL Audio > Kicker.
Yet JL doesn't have a single item that will suit my application for space requirements and power handling.
Thanks, dual 2 ohm then?
Old Feb 4, 2008 | 04:44 PM
Eric H's Avatar
US Acoustics doesn't have the specs for the USA2200F on their website. However, the other amps in the USA series appear to be stable to 4 ohms bridged mono.
Go with dual 2 ohm.
Have fun!
Old Feb 4, 2008 | 04:51 PM
JakeRobb's Avatar
Super Moderator
Alright, I'll bite. What are your requirements?
Old Feb 4, 2008 | 09:08 PM
megabass's Avatar
I have that same amp. Still going after 10 years. In 2ch mode it is 2ohm stable, but bridged it needs to see 4ohms. So D2 all the way.
Old Feb 5, 2008 | 08:08 AM
Just trust me Jake!
Heck yeah I love this amp. Still kicking after all these years is right... and come to think of it, mine is probably about the same age as yours. I first had it in my K5 Blazer when I was 19 years old I think... Which would make it 9 years old. It's worked hard pushing a variety of subs over the years.
BTW, I'm getting the box for this L7 from you. It's going to be for my Colorado Crew Cab... the down firing version.
Old Feb 5, 2008 | 10:40 PM
megabass's Avatar
Just trust me Jake!
I'll have to check to make sure the 10L7 will fit the col. d/f box. Probably will though. I think I got my amp in 1997ish. I had it in my camaro for awhile until I needed more power. It's in my truck now pushing four eD eu700s.
Old Feb 6, 2008 | 08:38 AM
I'm actually going ahead and just doing the 8... unless the 10 does fit...
