Took the car for a quick drive today...
Old Jan 27, 2008 | 04:34 PM
LT1-TA's Avatar
Got the wideband wired in nice so decided to take the car for it's first real drive since getting new head gaskets.
When started it was idling somewhat funny but smoothed out (lifters filled up maybe??). Drove it a bit to get it to temp and stopped to check idle again and make sure everything was ok. Seemed to be runnin good.
Took it for a blast or two and the a/f was about right on 11/1 (damn good job Brian. Helluva mailorder tune). Car felt good. After those few runs i came to a stop. Seemed to still be idling real good and all in order.
God a love turbos. lol. Friggin jsut rips the tires off. Never traction
I got back to the shop though and the car was idling wierd. It would idle for a sec like normal... then sputter, loose a few rpms, and go leaner on the wideband and then idle good for a few sec then sputter real quick again.
Any ideas on the sputter??? The car seems healthly besides that =/. Damn this thing.
Old Jan 27, 2008 | 05:54 PM
c0rey's Avatar
Not sure on the idel thing but glad to hear you got it going! Turbos are f ing sweet. Good luck.
Old Jan 27, 2008 | 07:47 PM
LT1-TA's Avatar
I was thinking possibly blew a vacuum cap or fittin off and got a vac leak.... not sure though. I hope so.
Old Jan 27, 2008 | 07:58 PM
c0rey's Avatar
Ya do you have vac caps on the tb or intake man? Check all those first. Where at in wyo are you?
Old Jan 28, 2008 | 02:10 AM
1982z28with18s's Avatar
What rpm is your idle at? Mine at 600 would kind do that, wouldn't stumble, just would give a unique pop every once in awhile. Turns out I had a bigger exhaust leak than I thought, which I think was a good part of the cause.
Old Jan 28, 2008 | 06:36 PM
LT1-TA's Avatar
Well i can see an exhaust leak giving you a pop and showin a bit lean on the wideband... But there is no pop.
It idles nice for a few sec then stumbles and comes back to idling nice again. Its not a consistant "stumble" or miss. Checked all vacuum lines and looked over everything today. Everything looks perfect.
I am at a loss. (didn't run it today though). With the turbo, I really am not trying to run it at all unless it is running perfect (scared of it coming apart or burnin down). So
Old Jan 29, 2008 | 03:35 PM
LT1-TA's Avatar
Took the car for another spin today since i had to relocate it anyways.
It started up and idled nice. Was I happy to hear that!
Took it for a hole like 6 block trip maybe. It got some temp by the time I was at
my destination and when I parked it, it was idling funny again.
So im thinking when it warms up, starts using the o2's, it gets a funny reading from the drivers side that was cut and extended with nothing but but connectors.
What you guys think?? Plausable??
Old Jan 29, 2008 | 04:56 PM
c0rey's Avatar
Datalog it? I would check the 02 first off and maybe get a new extension and see how that works.
Old Jan 29, 2008 | 07:13 PM
Boosted_Z28's Avatar
It's difficult to therorize about what may be causing the erratic idle. Get a monitor for an OBD II PMC and see what the sensor readings are.
Old Jan 29, 2008 | 08:49 PM
Ultra_Dog's Avatar
Where's your MAF in relation to the throttle-body? Is there the potential that some turbulence is being fed into it? The air flowing into the MAF needs to be fairly straight and not upset by other bypass hoses, etc. Should be about 4+ inches away from other tubes, etc.
Old Jan 29, 2008 | 09:22 PM
LT1-TA's Avatar
Yeah but my laptop is broke as am i. So don't have anything to log it with right now and can't afford a new one.
It is in the stock location of course.
97SSdude
Dec 31, 2014 07:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Absolute Z28
Jul 19, 2002 02:21 PM
