writeup for tranny pump replacement?
Old Jan 22, 2008 | 10:47 PM
LSWHO's Avatar
I have NO clue where to even look for this thing. Let alone replace it. Any one have any good writeup?
(4l60e)
Sorry, probably shoulda put this in the tranny section.
Old Jan 23, 2008 | 08:04 AM
Javier97Z28's Avatar
Moderator
Moving to drivetrain.. maybe someone has some help for ya there...
Old Jan 23, 2008 | 09:05 AM
Performabuilt's Avatar
Supporting Vendor
Pm Sent
Old Jan 23, 2008 | 12:18 PM
LSWHO's Avatar
Thanks for the writeup. Do you think that this may be my problem with the converter not grabbing when it's cold? The car drives perfect when it's warmed up, but it has trouble moving cold.
Old Jan 23, 2008 | 05:21 PM
Supporting Vendor
I would tend to think it would be the other way around if it was a pump issue since the fluid would be thicker cold than hot
Old Jan 23, 2008 | 05:34 PM
LSWHO's Avatar
Well damn. Now I don't know what to do.
Old Jan 23, 2008 | 06:57 PM
Supporting Vendor
Yes I saw your post here and somewhere else and its and odd symptom . Perhaps you can explain more . Like does it change gears and how do the shifts feel when its like this?
Old Jan 24, 2008 | 01:11 AM
LSWHO's Avatar
It shifts intermittently. I was told that it was probably because the PCM wasn't tuned for a 3k stall yet. It feels like the tc doesn't have enough fluid in it. Is it possible that there are air bubbles in there!? I would assume that it would work itself out if that was even a possibility. On my way to work this morning I let the car idle for about 2 minutes before I left and it drove perfectly fine.
Another thing... It seems like it's normal (I don't get above 10-15mph and barely any throttle) until I pull out of my complex. Then it starts. And when I get a 1/3 mile down the road it's perfectly fine.
BPS
9
Mar 5, 2015 10:51 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
ANDYZ28
Dec 29, 2014 09:13 PM
mattszm6
Dec 14, 2014 07:09 AM
pologreen97z
Dec 2, 2014 10:42 AM
