engine swap: stroker to 94 firebird
Old Jan 18, 2008 | 01:28 AM
lonmichels's Avatar
I've bougt a balanced crate stroker with and old 350 block that I was originally putting in a 88 camaro, not an Lt1 block. I have been told to change the k member but when I went to buy one they said it wouldn't work. Is there someone that will make mounts to fit this k member or what do I do, I can't see welding it in, to risky on my part. There is got to be someone who has done this in to a 93-97 camaro or firebird!
Old Jan 18, 2008 | 07:19 AM
Unless I am missing something, any side mount small block should mount with no problem to a 93-97 that had an LT1 in it.
Old Jan 18, 2008 | 12:22 PM
lonmichels's Avatar
The firebird originally had a 6 cylinder
Old Jan 18, 2008 | 12:52 PM
Then you need a K-member from an LT1.
Old Jan 19, 2008 | 07:50 PM
lonmichels's Avatar
Talked to sphon performance about buying a new k member and they said it won't work, need to use and engine plate, does that make sense to anyone.
Old Jan 19, 2008 | 11:23 PM
I am not aware that the side mount locations on an earlier SBC are different than the LT1, so it makes no sense to me. But, I might be an idiot.
(you would need to use the LT1 motor mounts)
I am surprised no one else has posted. I know there are guys out there with SBCs in 4th gens.
Old Jan 20, 2008 | 01:03 AM
BMR makes a specific model tubular K-member for installing a Gen 1 SBC. Look at part #KM005.
http://www.bmrfabrication.com/F-bodyChassis.htm
Old Jan 21, 2008 | 11:08 PM
lonmichels's Avatar
Hey Injuneer, that looks like the k-member that i am looking for, appreciate the help!
Old Jan 21, 2008 | 11:12 PM
lonmichels's Avatar
What should i use for and air cleaner? It is obvious that with a carburetor, the cleaner will sit to high, I should have gotten a fuel injected motor but it was originally going in a 88 camaro. Any ideas
Old Jan 22, 2008 | 05:28 AM
You've got a lot of issues to address. Will the distributor fit under the cowl without cutting out the wiper linkage? Are you keeping the stock PCM to drive the speedometer? How are you going to regulate the fuel pressure? Will it be a return or deadend fuel system?
Old Jan 22, 2008 | 08:47 AM
lonmichels's Avatar
Ya, I know I have along way to go
D1SC383LT4
Jan 26, 2015 01:41 PM
Injuneer
Dec 15, 2014 09:36 AM
CaRParts102
Dec 6, 2014 08:45 AM
