28" Mickey Thompson Street Radials
Old Jan 7, 2008 | 06:48 PM
97 RedSS's Avatar
Anyone running these tires on a 15" rim w/out having to clearance alot to make them fit? Looking for people's personal experience
I don't think the 26" tire will be enough tire for me but I don't want to have to hack my car up trying to make the 28's fit.
Cody
Old Jan 8, 2008 | 05:28 AM
The M/T catalog shows the 28x11.5-15 as a 28.0" diameter. Its going to be close. I fit a 28x11.5-15 QTP (28.0") with no problems, other than moving the axle back about 1/4". The inner fenders had already been clearanced for 315/35-17's. But when I put M/T ET Drag 28x10.5-15W's (28.1") on it, I had to cut back the leading edge of the rear bumper cover. With the street radials, you won't have the same growth problems that you would have with a non-radial drag tire.
I believe I've seen a post here from someone running the 28" ET Street Radials. If no one responds, try a "search".
Old Jan 10, 2008 | 09:24 PM
97 RedSS's Avatar
Didn't find anything in a search...hopefully someone will chime in that runs them..
Cody
Old Jan 13, 2008 | 03:17 PM
AutoRoc's Avatar
A 275/60/15 should be fine with the right rim spacing.
325/50/15 is a LOT wider.
Old Jan 19, 2008 | 03:52 AM
GoFast908Z's Avatar
Member
how do you move the axle back 1/4"?
Old Jan 19, 2008 | 01:54 PM
Adjustable LCA's.
Old Jan 20, 2008 | 09:52 AM
ABA383's Avatar
I have a 95 Formula and run the Bogart welded R/Ts 15x10s and the 275 60 R15 M/T radials fit with no mods..I have adjustable everything under there, but that was not a factor...When you step up to the 325 50s you have to clearance the front inner wheel well because they are wider, but both are 28" tall...
--Alan
Old Jan 20, 2008 | 11:10 AM
97 RedSS's Avatar
Thanks for the info! Looks like I'll try em myself!
GoFast908Z's Avatar
Member
yeah i'm gonna have to get adj LCAs now, went to mount the wheel and its contacting the front edge of the fender.
Old Feb 2, 2008 | 09:03 PM
97 RedSS's Avatar
Welp, put my MT 275/60/15's on today and they fit great. They sit directly in the center of the wheel well and I didn't have to grind on the brake calipers at all! They weren't rubbing at all anywhere either. It was fairly close in a couple places near the inner wheel well, so I massaged those areas with a hammer to give me atleast 3/4" clearance everywhere.
The MT's are installed on 15 x 10 draglites w/ 7.5" backspace.
Took these tires out on the street and gezzz do these tires hook!
Louey
Pacific
Oct 1, 2015 12:37 AM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
