expectations
Old Dec 10, 2002 | 08:40 PM
orange68's Avatar
expectations
i have a 68 camaro, runs 13.9 on motor only. its a 350 low compression, hot cam, all msd ignition, headers, edelbrock intake, holley dp 670, 4speed, 3.73posi car. i installed a topshot nitrous kit with 100hp jets. its a wet system WOT gated. does anyone know what kind of quartermile improvments ill get granted i get traction?
Old Dec 12, 2002 | 07:15 AM
drop top steve's Avatar
12.9-13.2, depends on traction. For every 10hp increase you should see .1 ET reduction.
Old Dec 12, 2002 | 09:10 AM
Derrick Redd's Avatar
I'd say high 12's with slicks.
Old Dec 13, 2002 | 09:45 AM
NXz28's Avatar
i went from about a 14.0 to 12.4 on a 150 shot...so you should be able to take off about 1 second if you spray in all gears...and add about 8-10 mph to your trap speed...
Old Dec 13, 2002 | 04:46 PM
COMNBYU's Avatar
Re: expectations
actually, closer to stock motors react a little better to n2o than radically modded motors, at least from my experience. your motor is basically a stock 350. i would expect AT least high 12s but dont be suprised if you see as good as 12.6-7.
good luck and make sure you have traction. its all worthless if you cant put the extra power to the ground!
Old Dec 15, 2002 | 12:07 AM
orange68's Avatar
thanks for the input, i guess we'll find out at sears point jan 1, ill let ya know how it goes
2QUIK6
Sep 17, 2016 02:31 PM
drt
Sep 27, 2015 04:39 PM
WPHIG2
Aug 27, 2015 06:37 AM
nd4spd200
Aug 21, 2015 09:30 AM
13qtr
Jul 19, 2015 05:30 PM
