Problem with my power window
Old Jan 3, 2008 | 12:06 PM
justinsbad95z's Avatar
Im not exactly shure what the problem is but my d4river side power window is not functioning properly. If you push the button so the window will go down it wont do anything. But if you tap the door as you hold the button down it will go gown a little each time. I dont know if there is a problem with the motor of if it is slightly off track. Please help me!
Old Jan 3, 2008 | 11:40 PM
Fatdog2's Avatar
Sounds like when my window motor went south.Sometimes when I would wait a while,it would work,then not.Go to Shoeboxe's sight for motor replacement.I got a rebuilt window motor from Napa 5 years ago for $55.00.Took me 8 hours,but brought a big smile to my face.Hope this helps.
Old Jan 5, 2008 | 12:14 AM
thanks man i guess i will give it a shot it really sucks to not a a functioning window.
Old Jan 5, 2008 | 01:15 AM
mrmint69's Avatar
Same problem. I replace auto glass for a living and hate working on the Camaro's. I replaced the passenger side a year ago and the coiled spring that is on the regulator came off and i could not get it back on. The window works but not as well as before. Now the drivers side is going out. I think the cheap motor on Ebay might be part of the problem. For $40 its hard to pass on.
Old Jan 5, 2008 | 10:13 AM
Craddock's Avatar
They are 50 at Advance Auto with lifetime replacement, so spending 10 or 15 dollars more for a lifetime warranty isn't too bad. It took me maybe 2 hours the first time I changed them out. That's without the glass though.
Old Jan 10, 2008 | 07:23 AM
dalynchmob's Avatar
I found one on ebay with a lifetime warrenty that works pretty dang good for 25 after shipping. I also had the problem with the coil spring. It's a two person job to preload that spring and get the thing bolted up. I didn't use those wierd rivets that came with my motor to mount up the regulator but instead little half inch bolts. Came in handy using bolts cause it took me a few tries to pre-load that spring taking the reglator off then on then off, till i got it right.
Old Jan 10, 2008 | 08:55 AM
1995blackttopta's Avatar
8 hrs? damn... mine too like 1.5 hrs, but then again it had been done before and all the holes were drilled, i simply had to take off the door panel, loosen the 3 screws holding the motor in (didnt even take them out of the door as i reused them) take out the speaker and slide the motor out from down there, then put the new one up, bolt iti n/plug it in and replace the door panel and speaker.... i thought it was gonna take longer than it did.
the trick i was told was to only unbolt the motor, not the regulator... and also my window was down which made it easier since i didnt have to hold it (and since my motor was 100% dead i didnt have much choice in having it up or down)
i think i paid $58.xx at autozone for one wth a lifetime warrenty... i think on something like that i'd rather pay a bit more and get a lifetime warrenty from someone like autozone, than get a lifetime warrenty from some unknown company on ebay.
Old Jan 10, 2008 | 09:48 AM
Green96Z's Avatar
Shoebox should have an install guide. I used rivets first to put the motor back in, but they ended up breaking, so I used screws with some lock washers. Just buy a motor from Autozone and be done with it. I wouldn't mess around on ebay for something you can get locally.
Old Jan 11, 2008 | 01:25 AM
Fatdog2's Avatar
Hope I did this right,anyway,first I had to get ready for this endevor,pulled the door panel off,saw the diagram on where to drill the holes,so I could drill out the rivets,once I drilled a few holes in the door panel(swiss chess almost to find the right spots),My drill bit was too short,and I couldn't work with the glass in the way,so I found some water sprinkler 1/2 plastic pipe (2 of them)and cut it down to brace the glass up(cut a V in the plastic pipe at the top),then went to home depot and got a big az drill bit,and drilled out the rivets in the motor support thing.Pulled the old motor out,put the new one in, (2nd trip to home depot)and used screws,washers(fun,kept dropping them,and nuts to),with socket set tighten it down.But I had to use mirrors inside the door panel to see what the heck I was doing along with a light inside the door panel.But while all this is going down(during the course of 7 or 8 hours,neighbors come by to see what I'm doing,the wife comes into the garage to ask questions,like,are you almost done,we have to go somewhere,ect.)The water softener guy comes by,the phone never stops ringing,sometimes I think mechanics really earn thier money.I forgot to mention-Back pain.Beer.
DirtyDaveW
Dec 1, 2016 05:37 PM
dale3in98
Feb 14, 2015 12:18 PM
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
MilkyClr69
Jul 29, 2002 10:01 AM
