Please help with belt squeak!
Old Dec 26, 2007 | 01:15 AM
GnarlyZ28's Avatar
My car keeps developing a belt squeak. It usually happens when there isd moisture in the air (rain, humid, dirve through car wash etc..) The squeak goes away after the car has warmed up. I am on my third set of belts, i have narrowed it down to the A/C belt. The pulleys look and spin alright and the tension seems to be correct.
Does anyone have any ideas on could be causing this noise?
Old Dec 26, 2007 | 01:54 AM
porksoda's Avatar
Its gotta be one of the pulleys, your car only has 1 belt. Put a screwdriver to a pulley and to your ear and listen to which is making the noise.
Old Dec 26, 2007 | 12:22 PM
Green96Z's Avatar
LS1 has a seperate belt for the A/C condenser. Try cleaning the belt grooves on the pulleys with an old toothbrush or something. What kind of belts have you tried? Some are better than others.
Old Dec 26, 2007 | 04:44 PM
GnarlyZ28's Avatar
Ive tried the delco belt, goodyear gatorback, and the gates belt.
Old Dec 26, 2007 | 04:49 PM
95 Bandit's Avatar
From: What's the difference, I've got nothing for sale
Closely inspect the belt edges-it may be that a pulley is out of line and running the belt on the edge instead of the center.
Old Dec 26, 2007 | 06:39 PM
moroso99's Avatar
ive had the same problem. it was the drive belt idler pulley for me. theres a write up on it at installuniversity.com
Old Dec 26, 2007 | 08:35 PM
96ZCamaro's Avatar
Check your tensioner. They do not always get loose when they go bad. Somtimes they get stuck and holds too stiff against the belt. But I am not sure if for the a/c compressor it has a separate tensioner.
Old Oct 10, 2009 | 05:28 PM
dtp's Avatar
dtp
Question about the ac belt. Is it always going around even when the AC is off?
Old Oct 13, 2009 | 11:02 AM
Z28SORR's Avatar
Yes.
Old Oct 14, 2009 | 05:11 AM
Yes... that's why the AC compressor has a freewheeling outer pulley, and a clutch.
Old Oct 14, 2009 | 07:10 AM
ptown's Avatar
Mine was the AC pulley. I put up with it for years, just recently took my AC out.
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
WPHIG2
Aug 27, 2015 06:37 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
