Et Streets on Salad Shooters
Old Dec 24, 2007 | 10:26 PM
Andrew R's Avatar
I was wondering if this would be an ok setup. 295/50/16's Miickey Thompson ET streets on stock salad shooters (16x8)
I was loking at the page on Summit Racing and saw that it was within the recommend wheel width. A few friends seemed to think that it was not a good idea, what do you guys think?
Old Dec 24, 2007 | 10:28 PM
DustinZ28's Avatar
295s on an 8inch wheels seems like a bad idea to me. never heard of anyone doin that.
Old Dec 24, 2007 | 10:29 PM
6SpdLT1Z's Avatar
As I told you via text message. Biggest I personally would put on a 16x8 is a 255/50/16 (IIRC, that's what came on C4 Vettes with 16's)
Old Dec 24, 2007 | 10:45 PM
Andrew R's Avatar
I don't care about how wide they are, I just want the tires to hook like a bat out of hell. I guess I will keep searching for something else.
Old Dec 24, 2007 | 10:48 PM
Andrew R's Avatar
Eric do you approve of this?
Old Dec 24, 2007 | 11:02 PM
6SpdLT1Z's Avatar
I bet you'll get best time out of ET Streets on 16" Salad Shooters, without going to a slick / racing wheels (Pro Stars?) You want lots of sidewall. Plus salad shooters are relatively light.
Old Dec 26, 2007 | 02:41 AM
Z-RATED94's Avatar
Exactly, to big of a tire on a 8" rim, will not have the right footprint. I wouldn't go with a tire more than a 1/2 inch wider than the wheel. And by the way, Summit and other catalogs, always have mistakes in them, when recommending tire size to wheel size, let alone other mistakes.
Old Dec 26, 2007 | 12:04 PM
The M/T website shows the acceptable wheel width as 8.0-10.0", but then they contradict this by saying "Acceptable practice for rim width is tread width plus or minus 1''. Using that guideline, a tire like this with a 10.8" tread width requires a 9.0 - 10.5" wide wheel.
The tire specs also carry this note:
† Specs are estimated, availability to be announced.
Old Dec 26, 2007 | 01:01 PM
n2ceptor's Avatar
Bad over hang(bulge) on wheel, plus it might rub against the inner fender........
Old Dec 26, 2007 | 01:50 PM
Z-RATED94's Avatar
That would be cross section, and yes very inportant to keep in mind when picking your tires.
LT14LIFE
Nov 15, 2015 06:22 PM
IndyZman
Oct 22, 2015 02:17 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
HAWG
Sep 25, 2015 11:41 AM
