stroker with old 350 block
Old Dec 21, 2007 | 11:52 AM
lonmichels's Avatar
I am having trouble mounting an old 350 block into a 93 firebird. It had a 6 cylinder fuel injected orginally. I can't find mounts and arms to match up to the under carriage. What is the problem?
Old Dec 21, 2007 | 02:03 PM
tomcowle's Avatar
Your either mounting it via a front engine plate or switching
k-members to a tubular that has old style mounts on it.
Old Dec 21, 2007 | 02:26 PM
The V6 chassis has a different K-member than the V8 chassis. If you are starting with a V6 setup, you will have to change the K-member.
Old Dec 21, 2007 | 02:30 PM
texas94z's Avatar
yeah new k-member.
Old Dec 22, 2007 | 10:18 PM
96ZCamaro's Avatar
Agreed.
Old Dec 22, 2007 | 10:34 PM
mdacton's Avatar
where you located? I have a v-8 k-member stock one.
Also check out spohn performance...he can make you what you need and take some wt. off the car too if you wnat to spend some money
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Drtryder
Apr 22, 2015 04:17 PM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
