Is it normal for AC compressor on with Heat= less MPG
Old Dec 2, 2007 | 04:01 PM
D James's Avatar
On my 2001 I noticed on the vent options the picture with the heater blowing out front vents with feet vents has the blue line, so I opened up the hood to see if the AC compressor would also be on. I assumed it would since this vent option is what I use for the AC, but I was surprised to see that compressor spining with any setting. I always assumed that the heat was seperate. So How exactly does the whole system work? I doubt that AC freon is being used while I have the heat on, and if that compressor is spinning doesn't that mean its just like its being used in the summer, which would use more gas mileage? Why does the compressor need to spin, isn't there some fan right next to the heater core that pushes the hot air?
Old Dec 2, 2007 | 04:12 PM
mrmint69's Avatar
Short answer. The ac compressor is used to dry the air so there is less moisture to keep the windows from fogging up.
Old Dec 2, 2007 | 05:30 PM
Originally Posted by owner's manual
The air conditioner compressor operates in MAX, A/C,
BI-LEVEL, BLEND and DEFROST when the outside
temperature is above freezing.
Old Dec 3, 2007 | 11:59 AM
Gord's Green Z28's Avatar
That's the bi-level setting. I rarely to never use it. It's only good for the summer when you have hot feet. But it doesn't seem to blow as much cold air into the car as A/C or MAX A/C.
Devinfoote87
Feb 12, 2016 03:21 PM
Aug 24, 2015 06:41 AM
karpetcm
Aug 14, 2015 03:02 PM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
