D1SC and Bypass Valve
Old Nov 30, 2007 | 05:09 PM
joe-96z1le's Avatar
I have a D1SC with the twin IC setup running 8-9 lbs. boost. I'm planning to do a FMIC and crank the boost up to 14-15 lbs. (maxed out). Will my ProCharger BPV work well with this boost level or should I consider going with a Vortech Mondo BPV?
Old Dec 2, 2007 | 01:41 PM
Boosted_Z28's Avatar
Which Procharger by-pass valve are you currently using? If is is the standard unit that ATI sends with their kits (Ford vacuum actuator), I would consider upgrading to a better quality BPV . I've never really liked the design of the standard ATI BPV and with higher levels of boost, they just don't appear to be up to the task.
Old Dec 2, 2007 | 07:15 PM
joe-96z1le's Avatar
Yea I have the standard Procharger BPV. Works fine but I am only running 8-9 lbs boost right now.
Old Dec 3, 2007 | 12:21 PM
KS91Z28's Avatar
You could either use another one of the standard bypass valves (ATI calls it the ProFlo surge valve), or take a look at ATI's Race Bypass Valve.
http://www.procharger.com/component_photos.shtml
Old Dec 3, 2007 | 03:09 PM
eastoaklandss's Avatar
i used a vortech purge valve!
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
95blkss
Jul 13, 2015 01:28 PM
