what exactly do they do to a pcm when reprograming?
Old Dec 7, 2002 | 09:42 PM
steelheart's Avatar
do they plug it in and make the changes? do they open it up? how are they dong this? i would like to see pics too if possible, i never took mine apart to look inside but im curious to see whats involved in how they reprogram....
Old Dec 8, 2002 | 12:20 AM
drop top steve's Avatar
INfo on timing, fuel mix, shift points, tarns line pressure, rpm limit to just a few are contaianed on a eprom chip in the pcm. You can d/l this info, change it and reburn the eprom.
Check out LT1edit and Tunercat, two of the more popular software programs for doing this.
Old Dec 8, 2002 | 02:10 AM
DOOM Master's Avatar
Well, it depends on what type of PCM you have, FLASH or EPROM. FLASH has what are called flash chips in them, allowing them to be reprogrammed simply by plugging into the interface connector and running a program to do the reprogramming. Nothing to take out, no hands to get dirty.
EPROM requires that the EPROM chip be removed from the PCM, erased by UV light, and then reprogrammed through a EPROM programmer. Put it back in the car and there you go, you have a new program for you PCM. Each has its advantages and disadvantages, but they both get the job done.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
