wiring harness compatability?
Old Nov 26, 2007 | 04:24 PM
Glenn98ZM6's Avatar
i have a 94 Formula (no motor or engine harness) and we are going to put a 96 motor and engine harness and computer in it. how compatable are these two (94 body harness mated w/ 96 engine harness)? is it just a plug and play deal?
all i really need is for the guage cluster to work, all else i have removed. the car will be a total race car and we are trying to use only parts we have laying around.
feedback please.
Old Nov 28, 2007 | 10:08 PM
RE AND CHERYL's Avatar
You will have to swap a few wires around on the engine harness conectors under the dash, other than that I think you'll be good.
Re'
Old Nov 28, 2007 | 10:25 PM
Glenn98ZM6's Avatar
from what i've found over the last few days is:
the PCM pinouts for the 94-97 PCM's are the same except that the 96-97 PCM's have additional circuits the 94-95 PCM's dont, and those are on pins that are not used on the 94-95 PCM's.
so why would it not work?
we will find out in a few weeks when we get to that point in the build.
Old Nov 29, 2007 | 05:17 AM
It will work, except as noted above, where the body connectors enter the passenger compartment. There are significant differences in those pinouts that need to be addressed. Shoebox has information on his website showing the various connectors, pinouts, etc.
Old Nov 30, 2007 | 12:44 PM
Green96Z's Avatar
Gonna have to wire in the crank position sensor too.
Old Dec 1, 2007 | 05:02 PM
fergymoto's Avatar
^Not if he is using an OBDI PCM.
Old Dec 2, 2007 | 10:21 AM
feedback please.
He's installing a 96 engine, a 96 harness and a 96 PCM.... it will have all the correct wiring. The problem will not be in the engine compartment. The problem will be interfacing with the body connectors.
Old Dec 2, 2007 | 03:26 PM
fergymoto's Avatar
Oh my mistake, I thought he was sticking with the '94 PCM.
gh0st
Sep 1, 2002 10:24 AM
Teal94V-6
Aug 31, 2002 09:21 PM
Brian-94TA
Jul 31, 2002 02:52 PM
CobraEatr
Jul 23, 2002 06:32 PM
