missing crank bolt
Old Nov 11, 2007 | 09:00 PM
greenmachinedriver's Avatar
missing crank bolt
i do some work from time to time on one of my freinds ls1 race cars. it has a monster 408 with etp heads andruns a 300 shot. near 1000hp. well i was aligning the car friday night and looked up at the balancer and noticed the crank bolt was missing, so i put a new one in. just hammerd it on with my 1/2" impact.
the next evening we go out to the track, made three passes and somthing made me want to check to see if the bolt was still there. it was infact missing! so we put the car back on the trailer and went home.
anyone ever had this happen to them before? i think it was probably because i did not torqe it to spec but i figured my impact would do well enough.
Old Nov 11, 2007 | 09:07 PM
2xLS1's Avatar
So you admit to not installing the crank bolt correctly and are surprised it doesn't stay in? Especially on a 1000 HP motor? Now if the balancer spun much on the crank, even installing the bolt correctly may not work.
Old Nov 11, 2007 | 09:20 PM
yes i do admit that i did incorectly install it, and i guess my real surprise was that the engine builder must have done the same thing. i think the balancer has a keyway macined into it to stop the balancer from spinning im not for shure though as its not my car.
Old Nov 11, 2007 | 09:28 PM
2xLS1's Avatar
Unless it was added, stock balancers/cranks do not have keyways, but you don't say what kind it is. Do you know the correct way to tighten a gen3 crank bolt?
Old Nov 11, 2007 | 09:33 PM
i think it has a keyway, it is anaftermarket lunati crant and i cant remember the brand of the balancer off hand but i know its high dollar. i dont remember the torque sequence off hand but im shure i have i written down somewhere. the next one will be done right and the crank/ balancer checked.
Old Nov 11, 2007 | 09:39 PM
2xLS1's Avatar
This is if you are using a stock GM TTY bolt.
Using old bolt, tq to 250 ft/lbs to seat the pulley on the crank.
Remove old bolt.
Install new bolt.
Tq to 37 ft/lbs.
Rotate bolt an additional 140 degrees.
Old Nov 12, 2007 | 08:06 AM
AL SS590 M6's Avatar
Moderator
Remove old bolt.
Install new bolt.
Tq to 37 ft/lbs.
And you'd better have big wrenches to do it.
Old Nov 12, 2007 | 11:37 AM
thanks for the spec. i have a 24 inch breaker bar and a chain wrench that shuold do the job just fine.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
