Key cylinder - Dealer item?
Old Oct 19, 2007 | 10:05 AM
shock6906's Avatar
I had some issues with turning my key yesterday in my 93 Camaro (M5 trans) and in a fit of momentary rage, busted the plastic tabs on it. So I suppose I need to replace it. Do I have to get the cylinder from the dealer since it has the pass-key system?
Old Oct 19, 2007 | 11:07 AM
Green96Z's Avatar
Yep, definitely a dealer item. However, when you get it, it comes with a key with no pellet in it. I got mine and then had to pay $25 more to get a new key cut. Shoebox shows the part number as 26033387.
Old Oct 19, 2007 | 11:16 AM
shock6906's Avatar
So if the key comes with no pellet, then won't I need to wire in resistors to disable VATS?
Old Oct 19, 2007 | 11:19 AM
Green96Z's Avatar
If you want to disable VATS then just hard wire in a resistor. But if you want to keep VATS like I did, then you need a new key cut for the new cylinder with the pellet resistance value that your EBTCM recognises.
Old Oct 19, 2007 | 11:32 AM
RE AND CHERYL's Avatar
The reason it comes with no pellet is so you have a key that is cut right for your new lock. It's only used so you can purchase a blank key with the right pellet and have it cut.
You could always talk to a locksmith about replacing the top of your lock. It's not hard to do. Consittereing the lock assy from the dealer is $100 and a new key is like $25 more for just one key, it might be worth it. You also need to find out what is jamming in your column or it will happen again.
Re'
Old Oct 19, 2007 | 11:48 AM
n2ceptor's Avatar
Carquest part # US-160L w/manual trans...... No pellet..... Cost around 45.00...
Old Oct 19, 2007 | 11:56 PM
NovaTodd's Avatar
It's like $50 or so from Schlep Boys. You can most likely get it from Advance, AutoZone, Kragen, ect for about the same. If you want to keep the VATS, you will have to have a new key cut (the new cylinder will come with a "code" key that has the key pattern required for the new cylinder) with the correct resistor value. I got key blanks on E-Bay for about $10 each (it has been a while since i bought them) and had the local True Value cut the keys. You can also get blanks at most locksmiths or the dealer - just bring a BIG jar of Vasaline for the dealer....
The alternative, if you don't care about the VATS, is to put a resistor in the circut and have a standard key cut.
HectorM52
Jul 30, 2017 11:46 AM
R@mpage
Apr 20, 2015 10:02 AM
Jan 23, 2015 01:13 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
