Max RPMs with heads/cam??
Old Oct 18, 2007 | 01:35 AM
jshelton2006's Avatar
I have an 02 SS and will be putting a FM13 or 14 cam in it along with Trick Flow heads. My question is what is the safe limit of rpms for the stock bottom end with this set up? Thanks
Old Oct 18, 2007 | 06:38 AM
AL SS590 M6's Avatar
Moderator
With an 02 you should be good to the limits of the cam.
Old Oct 18, 2007 | 07:19 AM
pasbonsimon's Avatar
FMS cam- shoot for 6800
duals springs in your trick flows with .040 Cometic gasket, and some hardened push rods
Old Oct 18, 2007 | 11:51 AM
Marc 85Z28's Avatar
Even with the better factory rod bolts, anything over 7000RPM and you're on borrowed time. ARP rod bolts should allow 7500. But what's the point of revving that high if you don't have the intake to support it?
Old Oct 18, 2007 | 01:01 PM
I will also be putting a fast 90/90 intake on it. H/C/I and all supporting mods...oil pump, timing chain, pushrods, etc...thanks for replies! i didnt figure the stock bottom end would allow 7000+ rpm, thats great. anybody know of anything i'm missing? also what size injectors would you recommend?
Old Oct 18, 2007 | 01:26 PM
BadgeZ28's Avatar
I would recommend hardened pushrods and good rocker arms if you are going over 6500 very often.
Old Oct 18, 2007 | 01:30 PM
Kraest's Avatar
Retired
The F13 makes peak around 6000 rpm and the F14 about the same or slightly higher. A 6500 shift and 6800 redline will be fine.
Mike
Old Oct 18, 2007 | 03:18 PM
Marc 85Z28's Avatar
For your application that you listed, Ford's SVO 30# injectors (aka red tops) work great and are cheap and reliable. They are closer to a 36# in an LS1 application though. If you can find the 42# for the same price, go with them instead - room to grow
Old Oct 18, 2007 | 09:01 PM
Kraest's Avatar
Retired
Yep. SVO 30# are fine for that application. I made 471rwhp with the heads/cam C5 with SVO 30#s and had plenty of duty cycle left.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
