Is there a fuse for the back up light?
Old Oct 17, 2007 | 10:34 AM
AsianSensation's Avatar
Backup lights are not working. Bulbs are good. Sockets not corroded. Maybe a grounding problem? Is there a fuse for the backup lights? Any other ideas or suggestions to look for? Car is a 1997 WS6 M6.
Old Oct 17, 2007 | 12:47 PM
n2ceptor's Avatar
Looking in a fuse book, it shows an ATO 20 fuse, but stops at 1996????????? Might call the dealership?????
Old Oct 17, 2007 | 02:12 PM
Green96Z's Avatar
There should be a Turn B-U fuse, 15 amp, in the interior fuse block. Check to see if it popped. After the fuse, the wires go outside the car, to the reverse lights sensor on your T56. The sensor is on the passenger side, midway along the tranny. Then the wires go back inside the car, out the back, to the bulbs, then to ground. This is from the GM manual for my 96, 97 should be the same more or less.
You can start tracing these wires (which will be a pain in the ***) or replace the backup light switch (which will probably cost you a bit). Good luck!
Old Oct 17, 2007 | 03:25 PM
Its in the Owner's Manual. If you don't have one, Shoebox has a link to online copies:
http://shbox.com/pdf/manuals.html
Old Oct 17, 2007 | 04:54 PM
U240's Avatar
I had the same problem it turned out to be the switch on the tranny. It wasnt very expensive and only took bout 20 min to change including jacking the car up
Old Oct 17, 2007 | 06:17 PM
Thanks guys. You're the best.
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
squarehead
Jan 15, 2015 07:02 PM
fpete1992
Dec 11, 2014 03:51 PM
CLEAR
Aug 30, 2002 07:49 PM
