Forged LT4 385 boost it?
Old Sep 27, 2007 | 08:46 PM
NewbieWar's Avatar
so my 94 firebird has an LT4 hotcam rebuilt
the crank was replaced and the pistons are forged...
guy who built the motor said it'll last all day at 10 psi...
any ideas?
Old Sep 28, 2007 | 09:44 AM
bad95formula's Avatar
Gotta give more details than that. Compression? Fuel system?
Old Sep 28, 2007 | 09:57 AM
NewbieWar's Avatar
guess i gotta ask more questions from the performance shop...
Old Sep 28, 2007 | 10:32 AM
jsetzer's Avatar
If it wasn't a specific request for low compression, your best luck will land you in the stock compression range. Bad luck could put you much higher with flat tops, stock heads, decked block and milled heads.
If its stock range I would probably run it 8-10 with good fuel, but that would be pushing your luck.
Old Sep 28, 2007 | 10:36 AM
NewbieWar's Avatar
yea i never mentioned compression when i had the work done...
all i originally wanted done was an lt4 kit.. hotcam
then he pulled it apart and was wondering why it worked due to the crank's condition seeing that it was burnt
so i had him stroke it after seeing the need for the new crank
unless the crank changes the compression, i think i'm the lt4 compression which is 11.1 isnt it?
Old Sep 28, 2007 | 10:50 AM
jsetzer's Avatar
crank, pistons, heads all go into it.... so its best to check. At least find out what pistons are in it.
So you did the whole lt4 kit? Heads, intake, etc?
Old Sep 28, 2007 | 01:00 PM
NewbieWar's Avatar
yep
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
