wiring question
Old Sep 25, 2007 | 11:58 AM
FireChicken1995's Avatar
wiring question
got a few questions about the wiring for all the gauges. i ust got XFI and im sure that il have to leave the PCM in for the gauges and what not but what if i went with all after market gauges? could i take out alot more wires for that? how does the speedo work? would it still need the PCM for it? i know the others will be easy. just woundering what others have done. thanks
Old Sep 27, 2007 | 11:10 PM
Black95Form's Avatar
I used the fast track splice in harness, still have the pcm for all the gauges.
Old Sep 28, 2007 | 06:14 AM
what wires from the PCM go towards the frount of the car besides the engine stuff? i have the FAST wire harness for the swap including the injector harness. i would like to take as much as i can out to make it a little more simple.
Old Sep 28, 2007 | 06:31 AM
Besides the fuel pump control, its all going towards the front of the car. All engine mangement.
Old Sep 28, 2007 | 07:39 AM
how do you like your XFI?
Old Sep 28, 2007 | 12:41 PM
The only gauges that depend on the PCM are the tach and the speedo. All the others are wired directly from the sensors to the dash..... no connection to the PCM. I run a MoTeC ECU. For the speedo, I kept my stock PCM in place, and allowed it to run the speedo/odometer. I use an aftermarket tach, so that comes directly off the tach output signal of the ECU.
It might be possible to interface the stock VSS directly to the speedo by running the signal through a Dakota Digital speedo interface..... worth looking into if you don't want to keep the stock PCM in the car.
http://www.dakotadigital.com/index.c...rod/prd126.htm
Old Oct 2, 2007 | 12:36 AM
il take a gander at it... i know i can wire up all the other gauges and make it look better than stock so i might do this. thanks
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Jan 4, 2015 11:15 AM
lbrowne
Nov 13, 2011 04:25 PM
Jul 4, 2005 05:00 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
