Custom Dual Exhaust
Old Sep 6, 2007 | 10:13 PM
JCCamaro's Avatar
Custom Dual Exhaust
torwards the beginning of 08 im going to try to get a custom exhaust set up, so far the plan is kooks 1 7/8s 2 step headers to an X-pipe then to some chambered mufflers, my question is though, what is your insight on the size of the exhaust? should i run 2.5" or 3" back from the headers for my best horsepower/sound? or is this just a bad idea in general? open to all suggestions but i really do want a custom dual exhaust. If i go with 2.5" im going to get my hands on some GMMG chambered mufflers but if i go 3" where should i look for some good chambered mufflers that arent too restrictive on a street/strip car? Btw the car is a 99 z28 and will hopefully have heads and cam one day, and i want this exhaust to stick around after that too.
Old Sep 7, 2007 | 07:49 AM
teke184's Avatar
2.5" pipes are more than adequate for 500hp
so i say stick with those for the ground clearance.
i've got 3" and while my clearance isn't bad...i wouldn't mind having 1/2" more sometimes.
Old Sep 7, 2007 | 08:34 AM
JCCamaro's Avatar
does your exhaust pop alot when you let off the gas?
Old Sep 7, 2007 | 10:58 AM
shock6906's Avatar
Mine does...
Old Sep 7, 2007 | 12:00 PM
teke184's Avatar
i don't think mine does at all...least not enough for me to notice
here are 2 vids of my setup
now this is on a cammed LS1....all i did was put mufflers on the Xpipe from one vid to the next. didn't even move the camera
straight pipes
magnaflows
Old Sep 7, 2007 | 12:56 PM
JCCamaro's Avatar
cool, i check it out after work since they blocked the videos
Old Sep 7, 2007 | 01:04 PM
Need4Camaro's Avatar
Nice, how much did the T/D setup cost you? I SERIOUSLY want to do that with my car. Who did it for you?
Old Sep 10, 2007 | 01:29 PM
teke184's Avatar
jegs universal 3" Xpipe
magnaflow 4x9 straight thru mufflers, 3" in/out
a couple of 3" ID 3-bolt flanges (flowtech headers are not slip fit)
a pair of turndowns from jegs
some U-bolts and a set of exhaust hangers
and a few hours on my back cutting and grinding to get the angles right (to get them tucked up and the pipe off the driver side which has an oddly angled collector).
then just took them to a shop around the corner for the final welding.
UNFORTUNATLY i had to have it all welded up 3 days before a Cat 5 hurricane (wilma) came through. so the driver side hangs a bit lower. but it workes for now.
Old Sep 10, 2007 | 10:50 PM
GaJoe's Avatar
tke, did that exhaust setup take away from your bottom end power any?
Old Sep 11, 2007 | 07:27 AM
teke184's Avatar
not enough to really notice...
at the time it was a reasonably sized cam, so the low end was not phenominal.
but it has no problem running down the highway (flat) in 6th gear turning 1400rpm
Old Sep 11, 2007 | 11:01 PM
xxsaint69x's Avatar
where did u get those turn downs?
Noct
May 26, 2016 10:26 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Queens94z28
Nov 20, 2014 06:03 PM
