2000 Silverado 1500, Ext cab, 2wd, 5.3L V8, Auto
Old Aug 24, 2007 | 10:04 PM
Hotwire's Avatar
Hey all,
I'm trying to get out of car payments due to medical bils and am unwillingly trying to sell my truck, all the projects are gone except for a lone LT1 block sitting in the shed...
It's Dark Blue Metallic w/ dark charcoal grey interior. Has the third door in the extended cab, tinted windows, power mirrors, locks, windows, tilt, cruise, intermittant wipers, lumbar support on driver's seat, and center console that folds up for a third seat up front. It has fold out cup holders in the dash, factory cd player that picks up stations great and sounds good.
I've had the ecm programmed by Bryan Herter @ pcmforless.com, put in a 87/89 octane tune, I'm averaging 18-18.5mpg right now running 87 octane, have seen 17-20mpg since owning it. I installed a trailer hitch and wiring, transgo shift kit w/ heavy duty seperator plate, large trans cooler, and inline filter to increase the longevity of the tranny. It has the factory deep pan. I've used synthetic fluids front to rear since I purchased it Dec. 04. Had 52K on it, it now has 102K, oil pressure w/ Mobil 1 5w-30 is 40/60 hot, using Napa Gold oil filter, and K&N air filter. I also have kept a service log. I did have a McGaughy's drop on it, but removed it, sold seperately, and got the front end re-aligned.
New NAPA ceramix brakes all the way around w/ new hoses and rotors up front. Windshield just replaced due to rock chip. Also I have lifetime alignment @ firestone dealers.
I have a sportsmaster soft tonneau cover and bedliner installed, tonneau rolls up within 5 minutes for quick hauling.
I set this truck up to keep it a long time, but unfortunately have to let it go due to medical bills. I'm going from this truck to a 88 GMC Jimmy if that tells the story any better. The a/c on the truck is extremely cold, I have always used a sun shade in the windshield if not parked in the garage. On the 100 degree days I have had to turn the fan down because the a/c works so well.
I live in Summerfield, NC which is 10 miles North of Greensboro. I'm asking $9200 and do have the factory Helms Service manuals too. I have had to do very little maintenance to this truck, it's been the best vehicle I have ever owned hands down. Can furnish more pics or information on request.
pass corner shot, magnaflow exhaust is gone, factory exhaust is back in place.
http://216.77.188.54/coDataImages/p/...-11-16007r.jpg
driver's corner, as clean as they can get
http://216.77.188.54/coDataImages/p/...-11-16015r.jpg
close up of crank pulley / front seal, never degreased or washed and the new a/c belt
http://216.77.188.54/coDataImages/p/...-24-07013r.jpg
oil pan from driver's side. shot w/ brake cleaner after every oil change to keep clean / watch for leaks
http://216.77.188.54/coDataImages/p/...-24-07015r.jpg
transmission pan, no leaks, changed the filter/seal/gasket/fluid 3400 miles ago, factory deep pan w/ the stock overtorqued drain plug that no one can remove
http://216.77.188.54/coDataImages/p/...-24-07016r.jpg
clean differential, yes I painted the bolts aluminum when I had them off inspecting the gears, gives it character.. :hahano: That was done 35k ago, just about time to change again, Monroe Reflex shocks
http://216.77.188.54/coDataImages/p/...-24-07017r.jpg
driver's seat, I'm 6'1", 220 lbs, thing rides like a mobile barcalounger
http://216.77.188.54/coDataImages/p/...-24-07018r.jpg
odo, yes, 101k, be sure to go back and check the underside shots again!
http://216.77.188.54/coDataImages/p/...-24-07019r.jpg
cup holder, accy oulets open, center console flipped up
http://216.77.188.54/coDataImages/p/...-24-07021r.jpg
center console
http://216.77.188.54/coDataImages/p/...-24-07022r.jpg
mini overhead console w/ reading lamps
http://216.77.188.54/coDataImages/p/...-24-07023r.jpg
pass side
http://216.77.188.54/coDataImages/p/...-24-07024r.jpg
overlooking driver's side from pass side
http://216.77.188.54/coDataImages/p/...-24-07025r.jpg
rear seats, have 2 daughters, been plenty of family trips w/ them loaded back there
http://216.77.188.54/coDataImages/p/...-24-07026r.jpg
rear seats folded up
http://216.77.188.54/coDataImages/p/...-24-07027r.jpg
bedliner, custom wooden cargo holder, and transgo kit w/ factory parts from valvebody and instructions in case you want to go back stock
http://216.77.188.54/coDataImages/p/...-24-07028r.jpg
engine bay. I washed it with soapy water and a long soft bristle brush last week when I was prepping it for sale. I have never washed the bay previous to this and have never used degreaser in the engine bay. didn't use any type of "dressing" to try and shine it up either, what you see is what you get
http://216.77.188.54/coDataImages/p/...-24-07032r.jpg
Truck has the owner's manual in the glovebox, plus the original touch up paint that has turned rock solid. Also noticed when I was taking pictures, BOTH front seats have adjustable lumbar support!
If you want any other pictures or feel I'm intentionally not taking pictures of certain areas, please let me know, I'd be more than happy to take / post them. The floor mats are dirty from me driving it around after I detailed it, but are easily cleaned, they're a hard plastic that wipe clean.
Buyer will recieve complete issue / damage disclaimer, service log, and Helms Service manuals.
Thanks for the interest.
Jeff
shroyvin56
Apr 3, 2015 08:15 AM
jayvar
Feb 2, 2015 10:00 PM
Caps94ZODG
25
Oct 2, 2003 06:30 AM
Christopher
Sep 14, 2002 03:08 AM
ced8
Jul 8, 2002 11:03 AM
