New dtc's: 16, 41, 42, 51
Old Aug 24, 2007 | 07:04 PM
AdsoYo's Avatar
When I started my car this moring, this is what the scanmaster was showing:
dtc 16 - Distributor ignition system (low resolution pulse)
dtc 41 - Ignition Control (IC) circuit (open circuit)
dtc 42 - Ignition Control (IC) circuit (shorted or grounded circuit)
dtc 51 - EEPROM programming error
A few weeks ago it was showing codes 36 (Distributor ignition system (faulty high resolution pulse or extra low resolution pulse detected) and 44 (Bank 1 (left) Heated Oxygen Sensor (HO2S) Circuit (lean exhaust indicated) which both dissapeared after I installed the pcmforless computer I ordered.
It ran fine, I didn't notice anything out of the ordinary. Could my plug wires cause any of this? I noticed one of them arcing and I have replacements on the way. The opti is only 20K miles old. Could pcmforless have sent a bad pcm? Any help is greatly appreciated.
Old Aug 24, 2007 | 10:44 PM
The first three (when together) are often associated with the opti or it's electrical harness.
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
