Dyno numers for XE 230/236 with stock heads?
Old Dec 1, 2002 | 11:33 PM
KCFormula's Avatar
Does anyone have any numbers for a XE 230/236 with stock heads? Or a similarly large cam?
Old Dec 2, 2002 | 11:29 AM
RealQuick's Avatar
Mine are rather disappointing #'s. I home ported the heads and probably cause some turbulence and increased the runner volume too much. #'s in sig.
Old Dec 2, 2002 | 12:37 PM
mtxpert's Avatar
Well then I should be ecstatic because that's about 100 HP more than my setup now and I'm installing mildly ported 96 aluminum heads and that cam!
My current low 14's should drop to low 13's w/o juice and high 11's with.
Mike
Old Dec 2, 2002 | 03:26 PM
RealQuick's Avatar
I ran 13.38 @ 105.8 before cam with bolt-ons and street tires. That cam should get me in the mid 12's.
Old Dec 2, 2002 | 03:37 PM
97Z-M6's Avatar
im porting heads as we speak and will be running this cam. and am curious about the numbers people are putting down with it.
Old Dec 2, 2002 | 07:01 PM
KCFormula's Avatar
I love the numbers that the CC306 makes but I want the torque up there also. I dont want to spin the motor much over stock redline. Is this too much to ask?
Old Dec 2, 2002 | 07:03 PM
Teal94Z's Avatar
I am installing that cam, and home ported heads as we speak, I am shooting for around 375 or so, depending obn how good my heads are....
Old Feb 25, 2003 | 08:06 PM
NiteRider's Avatar
Which XE 230/236 are you guys running? There are 3 different ones!
Old Feb 25, 2003 | 08:35 PM
Teal94Z's Avatar
I have the Extreme Energy 230/236 on a 110 lsa, the one made for the LT1...
Old Feb 25, 2003 | 09:16 PM
97Z-M6's Avatar
om going to be running the 230/236xh .585 lift with 1.5rr but its going to be on a 108lsa.
Old Feb 26, 2003 | 06:55 AM
RealQuick's Avatar
Mines on a 114LSA.
Old Feb 26, 2003 | 07:12 AM
Ken95Z28's Avatar
In a couple of weeks should have some numbers for this.
This subject has came up in the past just not enough people running them yet. Most of the ones I have seen as in RWHP has been rather on the low side. Kmook, (I think) put down close to 400 with this cam.
I'm using a 230/236 on a 111LSA.
I'm also using Combination Motorsports heads (Stage II)
Like with everthing else tuning is very vital to the performance of any cam. It let's you get the most out of it. Heck, I got 342 with my HotCam setup and that's on stock heads! This setup I'm hoping to put me close to the 400 mark.
Old Feb 26, 2003 | 08:04 AM
ltlhomer's Avatar
I went with the "normal" xe230/236 which is the .510" / .520" with 1.5's, and .544" / .555" with the 1.6's that I'm using. It is ground on a 112 lsa and I'm complimenting with heads that flow about 260/200 and I'm also hoping for close to 400 at the wheels. As of now, the car is torn down to the block in my garage :-). Time for the install!
Old Feb 26, 2003 | 09:51 AM
All_Z_Way's Avatar
I have this cam sitting in my garage waiting on me to pull my heads and have them ported.
xe230/236 on 112lsa
Old Feb 26, 2003 | 10:56 AM
jonaddis84's Avatar
I think everyone misunderstood his question. He wanted to know numbers with stock heads. From reading other posts, I would not recommend that cam with stock heads, unless you are going to port them in the near future, in fact you might not see much of an improvement at all with that cam and stock heads. That cam is a pretty extreme cam, made for well ported heads, if you have those its the best, but you want something a little more tamed than that for stock heads. Thats what I think.
