who has an aftermarket radiator????
Old Aug 3, 2007 | 03:39 PM
FireChicken1995's Avatar
im gonna be a aftermarket radiator to make some room sooo anyone done the while putting a aftermarket radiator in the core support?? all i really need to know is what size radiator and what you did with the steam pipe. can i just run the steam pipe to an overflow tank? or would i have to T it into the drivers side main coolant hose? thanks
Old Aug 3, 2007 | 09:16 PM
nevermind i figured it out... if anyone wants to know how to do this PM me.
Old Aug 4, 2007 | 06:31 AM
Hopefully you figured out you can't dump the steam pipe into the overflow tank.... all your coolant would pour out of the system. The stock radiator is supposed to have a vapor/liquid separator where the line from the back of the heads connects. My Griffin radiator has all the factory connections, including the steam retrun, level sensor, etc.
Old Aug 4, 2007 | 07:00 PM
so what would happen if i got the griffin radiator (GRI-1-25241-X) and tapped into the side tank for the steam pipe? if you have a radiator like this whats the part number? also would you happen to know the CFM for each of the stock coolant fans? thanks
Old Aug 5, 2007 | 12:09 AM
I bought the Griffin 7 years ago, and can't find the receipt. It's their model for an LT1/M6 F-Body. No smaller than stock though. Thicker, and a shade taller.
You should be OK dumping the head return line into the radiator. I never pulled the stock unit apart to see what was inside the connection.
Don't know anything about the stock fans, other than that they are enough to keep my engine running cool under virtually any operating conditions.
Old Aug 5, 2007 | 12:35 AM
ok cool, well when i get back im gonna give it a shot and il post up the results. hopefully it dont blow the radiator cap off. only problem i see is excess vapors in the radiator which should be able to escape from the over flow.
Old Aug 5, 2007 | 11:00 AM
If you get the right model, you won't have to "tap" into anything. Mine has the connection for the steam pipe - pointed that out in my first post.
Old Aug 5, 2007 | 11:07 AM
mdacton's Avatar
I think they quit making that model.......I'm sure if contacted they will put one together. But when I was looking for one noone could get it.
Why do you need more room? turbo or something?
Old Aug 6, 2007 | 09:42 PM
yea i need room for the turbo, cant seem to find any radiator that is the right size that has a spot for the steam pipe other than stock type/size radiators which would be pointless for me to buy b/c that wont save any room. i wasnt going to just tap into the tank i found some aluminum bugs that i could tig on to the tank. the griffin seems like my best option so far with a set of push fans. when i get done doing this im gonna make a write up for it.
Old Aug 6, 2007 | 09:51 PM
mdacton's Avatar
I have seen guys use one thats not so tall and move it more forward(some had cut the upper metal out)
Some of the guys at LS1tech have done it....but none of them are street cars so not sure how well they cool
Old Aug 6, 2007 | 11:57 PM
i plan on cutting the core support, the car wont be a daily driver just a weekend fun car and will see the drag strip alot.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
SEOJustin
Sep 24, 2015 04:39 PM
Bxlt1
Sep 10, 2015 08:16 AM
Pwilson59
Sep 3, 2015 08:47 PM
