Is it safe to remove the upper panhard bar??
Old Jul 29, 2007 | 12:52 PM
detroit1994z28's Avatar
Okay I have a 94 camaro z28. I currently run 15x3.5" rims up front. I removed the front sway bar already. I was wondering could I remove the upper panhard bar only?? I plan to keep my lower one on still - which is a aftermarket non-adj umi bar. Would it be safe to remove it. Like mentioned I really dont go crazy in turns/corners anymore because of my tires up front. Also My exhuast is hitting it also so it would be nice to remove it.
Old Jul 29, 2007 | 01:14 PM
hotpart's Avatar
Former Vendor
No do not remove it. It helps locate the axle under the car.
Old Jul 29, 2007 | 07:06 PM
blown94's Avatar
There is one company, sorry i dont remember which ATM, that makes one which 'relocates' the bend in the upper panhard bar to remedy this problem. Look around at the f-body suspension fabricators and im sure you'll find it.
Old Jul 29, 2007 | 10:49 PM
The panhard rod attaches to the upper, so removing it would be a disaster.
Old Jul 30, 2007 | 10:14 AM
Shon Herron's Avatar
My car does not have it but it's 100% trailer queen to the drag strip.
Old Jul 30, 2007 | 11:01 AM
mitchntx's Avatar
Without it installed, I have seen cars with ripped PHB chassis mounts.
I would leave it in there.
Old Jul 30, 2007 | 11:22 AM
Thanks everyone. I will just keep it on. I thought maybee I could get away without it since I really dont drive aggressive in corners,turns anymore
Old Jul 30, 2007 | 05:07 PM
Mid 8-second 97 SS convertible. On this car, the panhard rod has been dropped lower on both ends. The body end bracket, which would normally be stabilized by the upper rod, has been reinforced, including the mounting point at the chassis. Had no problems in a drag application.
Old Aug 1, 2007 | 06:50 PM
drumer919's Avatar
BMR
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
