Installed my Sportlines today
Old Jul 25, 2007 | 09:38 PM
jer4251's Avatar
Well i tried anyways.
i did the rear first. went pretty easy.
and then i went ahead and started the front. It wasnt as easy. I did the drivers side first, moved the master cylinder, unbolted everything, couldnt get my tie rod end links off so i just said forget it and left the sway bar in place. took a while but i got it all worked out.
moved onto the pass side, unbolted everything, left the sway bar again, droped out the coil over and upper arm,
thats when i ran into a little problem, as i like to call it.
i compressed the spring, went to unbolt the nut that holds all the springs tension, and the thing is completely rusted, and good for nothing, It's not coming off without a grinder, which i dont happen to have.
Now i dont know weather to buy a new strut and upper mounting hardware, and just trash the old one, or to take it somewhere and see if they can do something with it.
I should be able to find the parts pretty easily, but i want it done now. i ran out of time tonight, so its got to sit till i have time tomorrow to mess with it.
the nut is basicly fused with the end of the strut treads. I know when u replace one strut, they say its best to do them both at the same time, but i dont want to spend the money. and i already had it completely apart and back together.
Anyone know of a good place to take it to? i rented the spring compressors from autozone, not sure how long i'm suppose to keep them for.
warmeck
Mar 22, 2015 10:28 AM
ModdedNerd
Feb 5, 2015 04:37 AM
Collector Car
Jan 5, 2015 10:58 AM
Dec 1, 2014 08:08 AM
StngStlkr
Sep 6, 2002 05:47 PM
