what kind of tires? I live in boston.. Corvette rims...
Old Jul 25, 2007 | 12:47 PM
djk19's Avatar
I am thinking of wrapping my c5 rims in:
FRONT: 255/45 17
REAR: 285/40 18
I live in boston and I worry mostly about rain. I need the best traction possible in the rain and I don't trust the comments the manufacturers make when advertising the tires. I need the truth... So good in the rain and for performance. forget the run flats... I have them on there now adn it is so stiff it is ridiculous... Thanks guys. kurt
Old Jul 25, 2007 | 01:01 PM
87DJP2001's Avatar
Go to tirerack.com and check their comparsion of various brands and comments from users/
Old Jul 25, 2007 | 05:26 PM
djk19's Avatar
I did that. I dont trust it. no one cares?
Old Jul 25, 2007 | 07:54 PM
87DJP2001's Avatar
Don't trust that site, but will take some 16 yr olds advice here. Good luck
Old Jul 25, 2007 | 09:05 PM
djk19's Avatar
haha thats funny at least i'm not on a website trying to belittle others
Anyone who is OLDER THEN 16 and has good experience with what tires are a good deal right now and have good traction etc refer to original post before ranting... Anyone?
it's weird I swear when I bought my first third gen and was learning about that stuff and was a real camaro newb.. people posted more frequently, there were more knowledgable and mature people and things were a lot easier...
Old Jul 25, 2007 | 10:53 PM
Wrong forum...... again.
Moving....... again.
Old Jul 26, 2007 | 12:09 AM
djk19's Avatar
my bad injuneer. I think when I first started posting on this forum there were a lot less "sub" forums and no one ever moved anything I posted....They are hidden under the care and maintenance...
Old Jul 26, 2007 | 12:50 PM
ttop1986's Avatar
I use bf goodrich geforce KD's, and they work fine in the rain. They make KDW which is more intended for the rain though.
Old Jul 26, 2007 | 03:55 PM
Greed4Speed's Avatar
I like the Falken RT-615 better than I liked the BFG KD. I just don't know if they'll come in your sizes. They do fine in the rain, but I wouldn't say they're the best. You'd probably be better off with something like the BFG KDW, Nitto 555, FS Wide Oval, GY GSD3, etc for wet road traction. A dry/wet performance tire or a true all season is what you should look for.
I've had good luck with the feedbacks on tirerack, but I read the ones from people with RWD and skip the stuff from the fwd or awd cars.
Old Jul 26, 2007 | 05:25 PM
A 285/40-18 tire is 27" diameter, larger than the stock tire diameter. A 285/35-18 would be a better choice. If your car left the factory with the Z-rated tires, they were 245/50-16 with a 25.65" diameter.
The user feedback rating on Tire Rack are fairly accurate, from my experience. I run the BFG KDW's in the front. If I was buying today, I'd consider the GY GS-D3.
Old Jul 26, 2007 | 06:14 PM
djk19's Avatar
not bad not bad.
My wheels are corvette c5 rims and yes the factory puts out 275 width. I saw somone running the 285 and figured I should too to get that extra traction.. I live in boston and I can't go to a 35 height. that is too thin for the roads here which are GARBAGE to say the LEAST. The roads here are absolute trash and my camaro having the all solid rear suspension has it rough enough. I am eliminating the run flat rigidity... Sounds like some sound advice. i'll go check those out.
Old Jul 26, 2007 | 08:20 PM
camaroboricua's Avatar
I have 295/35/18 on the same wheels but i havent had a chance to drive it in the rain yet. Tires are firestone firehawk wide ovals. They do pretty good in dry weather. The car is currently in the shop but ill post again when I get it back.
Old Jul 26, 2007 | 09:58 PM
CamaroRacing12's Avatar
are u in bston or suburbs?
Old Jul 26, 2007 | 10:09 PM
djk19's Avatar
touching both. I live in dedham and happen to live right next to west rox. about a quater mile down the street from the v.a. hostpital at the intersection of the vfw parkway and rt. 1 To answer the question. Suburb, very close to boston line.
why? you close?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Moshbmx1
Jan 20, 2015 03:27 PM
Hoodshaker
Aug 27, 2002 02:32 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
